I don't recall having any trouble reaching the lower firewall flange rivets with my no-hole yoke. I only had trouble with the lower side rivets. I pulled the mount off the firewall by an inch or so. With an engine hoist connected to the engine mount, took about an hour or so, but given the weight of the engine, it's probably best as a two-person job. If you have no slack in any wiring you've done, or if your engine control cables are installed and have no slack, pulling the mount is probably not a good option and you'll likely have to use pulled rivets. Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
