Old 06-03-2006, 07:51 AM
skidmk skidmk is offline
Default Practice kit question
Just finishing my practice kit (2nd one I've builit the tool book already) the trailing edges do not line up, one is shorter than the other, lining up the "trailing edge piece" flush.. should I then just trim off the excess?
Mike
Mike Bourget
Ottawa, Ontario
Old 06-03-2006, 09:05 AM
Low & Slow's Avatar
Low & Slow Low & Slow is offline
Mike,
Is it possible that you got the top skin on the bottom and vice-versa? I managed to do that at the SynergyAir workshop and the result was as you describe, the trailing edges didn'tcome out even.
James Jennings
RV9 Empennage
Old 06-03-2006, 10:35 AM
Default Wow!!,,
that just might be it.. I'll switch them around and check...
thanks
Mike
Mike Bourget
Ottawa, Ontario
