There is plenty of higher pressure air under the cowl wanting to escape. What escaped through my top rear hinge area was not enough heat to keep winshield from fogging up two weeks ago. There was about 1/2" dry snow at the airport. I preheated engine and cabin for the family(4 of us). After a five minute taxi/runup behind a 172(yep, was not the first to make tracks), then takeoff at 21F, all windows started fogging up on initial climbout. Thank goodness for two 80 mm 12 volt computer fans(defrosters). It was our first time using them and they worked great. My side windows cleared five minutes later as cabin heat is way more than enough. Kept a microfiber cloth handy just in case.
Good judgment comes from experience, and a lot of that comes from bad judgment.
