Old 06-02-2006, 05:25 PM
markscogg markscogg is offline
Question What tape for trying rudder trim tab?
What kind of tape should I use for trying out a rudder trim tab?
Rudder is already painted - don't want to hurt the paint when pulling it off.
Mark Scoggins
Charlotte, NC
RV-6 bought,flown and sold.
Rv-4 bought, flown and sold.
Old 06-02-2006, 05:46 PM
jclark jclark is offline
Duct tape ("200 MPH tape") worked fine for me.
I taped it down good and flew for several hours of testing with it.
Once done (appropriate length determined), double sided tape worked.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 06-02-2006, 06:35 PM
Build9A's Avatar
Build9A Build9A is offline
Default carpet tape worked for me
I just experimented with my rudder trim tab today. I used double sided carpet tape from Lowes. Flew with it, landed removed the tab and stuck it back on with same tape, flew it again and it worked fine. Not sure if the tape is the permanent solution. Some say it will hold for years. Jack
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
Old 06-02-2006, 08:28 PM
penguin penguin is offline
I used carpet tape and found the trim tab on the floor of the hangar the other day - the glue had melted when the temperature got into the high 90s! Now I will have to get it all painted and pop rivet it on.
Pete
Old 06-03-2006, 05:00 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Question Sticky Situation
....I used double sided carpet tape from Lowes. Flew with it, landed removed the tab and stuck it back on with same tape, flew it again and it worked fine. Not sure if the tape is the permanent solution. Some say it will hold for years. Jack
Almost ditto........ It gets pretty steamy around here, but after months of bonded integrity using the double sided carpet tape that Home Depot carries, I felt confident enough to leave it in place and went ahead and faired the forward edge of the tab to a smooth transition with the rudder using proseal. Its all painted now and only time will tell if that was a good idea or not.
[IMG][/IMG]
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 06-03-2006, 06:35 AM
N162RV's Avatar
N162RV N162RV is offline
I used a 3M heavy duty double sided from Wal-Mart. This stuff is tuff. I had a time getting it off to adjust the lenght of the trim tab. I think if I had it to do over I would use the duct tape method till I got the trim tab where I wanted it and then the double sided tape for the permanent solution.
Scott Frierson
Picayune,MS
RV6A 160HP
(Sold)
RV12 (sold)
Old 06-03-2006, 08:04 AM
Mel's Avatar
Mel Mel is offline
I used carpet tape on a customers -6. It worked fine for about a year. When he brought it in for the next annual condition inspection, it was gone along with the paint under it. I replaced it with blind rivets.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
