Old 01-19-2012, 04:40 AM
Tomas J's Avatar
Tomas J Tomas J is offline
Default Carburetor for O-320/160
I need to find the right carburetor for my Lycoming O-320-E2D that is converted to 160 hp with high compression pistons. If anyone can give me assistance I would be very grateful.
Tomas Johansson
Flying RV-4, and Super Cub on floats and skis
in Northern Sweden in Skandinavia
Old 01-19-2012, 05:55 AM
krw5927 krw5927 is offline
My E2D has a MA4-SPA carb. I havent changed the compression from stock but I believe the same carb would apply.
Kurt W.
RV9A
FLYING!!!
Old 01-19-2012, 05:58 AM
fixnflyguy fixnflyguy is offline
Default MA4-SPA
I have an MA4-SPA on my 160 hp O320-H2AD...works great.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 01-19-2012, 06:17 AM
rv9aviator rv9aviator is offline
MA4-SPA is what I have on my E3D engine from a Piper Cherokee 140. I bet someone will will have the exact combination your asking about though. Ask Mel.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 01-19-2012, 10:16 AM
Tomas J's Avatar
Thanks for the inputs.
Yes, it shall be the MA-4SPA, but it is available in different versions, including a different nozzle - 10-5009 and 10-5217. There is also a 10-3678-32. Does anyone know the difference between them? It's seems logical to use a bigger nozzle for the converted engine - is that the fact with -32?
Tomas Johansson
Old 01-19-2012, 11:06 AM
rvator51's Avatar
rvator51 rvator51 is offline
The 10-5217 includes an atomizer on the nozzle. It sure works great in our RV-4 with 160 hp. We can run lean of peak with it while we could not with the previous carb.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 01-19-2012, 11:16 AM
jrs14855 jrs14855 is offline
Default carb
The atomizer nozzle can be added to at least some of the different pn carbs. the 5009 with the atomizer nozzle becomes 5009N
Old 01-19-2012, 12:28 PM
Doug's Avatar
Doug Doug is offline
My O-320D1A (160 hp) came with a 10-5217 carb.
Doug Gray
Old 01-20-2012, 01:32 PM
Tomas J's Avatar
What I have find out to now it that I can use 10-5217 or 10-3678-32. I have got indication that the 10-3678-32 would lean the mixture somewhat at partial throttle, might leading to less fuel consumption. Is there anyone having an idea about or experience of this.
Tomas Johansson
Old 01-20-2012, 01:52 PM
penguin penguin is offline
Drill the main jet to 0.101" or 0.104" to ensure you have sufficient fuel flow for proper cooling at full power. I don't know what part number that jet is. I started with an O-320-E2D from a C-172 with an MA4-SPA, had the engine rebuilt to 160hp and had to go 0.101" to get the CHTs to even a sensible number. Cowling louvres have also greatly helped.
Pete
