Old 01-17-2012, 05:59 PM
dbaflyer dbaflyer is offline
Default Squeezing AN470 AD5 rivets
I have an enlarged hole on my flap brackets so I ordered some AN470-5-9 rivets from Spruce. They look like the rivets I need, but one thing is worrying me. I test squeezed one in some scrap (I cut this one down to a 6 length) and it felt like squeezing butter. Unlike the smaller rivets which I have to give a pretty firm squeeze to. Is this normal with this size rivet? I expected the larger size to take even more oomph on the squeeze. The rivet head has a "01DC" marking on it. The spruce item was "AN470A-5-9 SOLID ALUM RIVET AN470A-5-9"
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 01-17-2012, 06:01 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
You got the wrong rivets. Those are soft, you want the AN470AD-5-9 rivets.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-17-2012, 06:17 PM
SledDog SledDog is offline
Denis,
I ran into the same problem. In fact, with the same size rivet. I ordered AD rivets. AD rivets were indicated on the invoice. The bag said AD. And I used them on the horizontal stabilizer. The rivets felt way too soft. After checking, I found these were A rivets (soft), not the AD rivets I ordered. I contacted ACS and they shipped the correct rivets. Ever since then, my SOP is to look for the little dimple in the rivet before I squeeze or buck. The dimple indicates an AD rivet. No dimple is an A rivet and is very, very soft.
Roger Grahl
Lac du Flambeau, WI
RV-9A Slider
Empennage - Completed
Wings - Completed
Fuselage - Completed
Finish Kit - Under Construction
VAF donation through October 2020
Old 01-17-2012, 06:26 PM
DanBaier's Avatar
DanBaier DanBaier is offline
What he said. The "A" rivets are pure aluminum and the "AD" are alloy - much stronger.
As an aside, the "A" rivets work well in fiberglass where you don't have structural issues and you don't want to damage the fiberglass with a hefty squeeze.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 01-17-2012, 06:31 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Always check your rivets, Van's has also supplied soft rivet in some kits in the past.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-18-2012, 06:04 AM
krw5927 krw5927 is offline
Get that A-material rivet outta there. Shear strength, even though it's bigger in diameter than the AD4 rivet, is about 50lbs less. I have some AN470AD5-8's and I'd be glad to pop a couple in the mail if you don't wanna buy a bunch from Spruce.
They have to have the dimple in the center of the head to be the material that Vans designed for.
Kurt W.
RV9A
FLYING!!!
Old 01-18-2012, 06:23 AM
I have some AD rivets on order now. Thanks for the help in seeing the difference. Sometimes you get into a hurry in ordering stuff and it's only one letter off.. The rivet in the picture is in some scrap so no need to remove anything from the plane.
RV-9
Old 01-18-2012, 08:15 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default driven rivet head size
Looking at the photo, i have to comment. I could be wrong but that shop head appears to be under driven. A miss conception is driving the diameter
to 1.5 the diam. of the shank. and not getting the right driven height.
Please look at the very useful mil. spec. guide on the vans web site. Take special note of table 3. http://vansaircraft.com/public/Specs.htm
Note that according to this spec. there is no max diam. only min. and the height has a min and max. Rivet guides are ok but can be misused. For example, when you measure the diam of a shop head and it doesn?t fit on the rivet guide, one could be misled that the rivet is over driven when in fact it is not. My recommendation is to buy a thousands gage, digital or analog, use the butt end of it to measure the height of the shop head.
Al Girard, Newport, RI
N339AG
RV-9
