Old 01-17-2012, 12:35 PM
TX7A TX7A is offline
Default 2-10 Switch For Wig-Wag
Okay, I've looked at so many switches & diagrams my head is swimming. I want to use a S700 2-10 switch (B&C) to operate my lights for either wig-wag or always on. The switch position & operation would be:
o BOTH
o WIG-WAG
o OFF
I found this: http://docs.rapidlibrary.com/documen...10+Switch+.pdf
...which looks like what I'm looking for. Anybody recognize this?
Does the note: "2 of 4 diodes in a bridge rectifier or 2 schotkey assemblies" mean the use of a diode like B&C sells for E-Buss?....and the schotkey assemblies like Perihelion sells?
Would be the wig-wag module be like that which B&C sells?
Also, I'm using the stock 75w halogens Van's sells in the wingtips. Therefore, I don't 'think' I need the inrush limiters...right?
I know there are many ways to skin this cat, but my panel holes are drilled, placards have been engraved and I need to use the 2-10 switch.
I'm feeling pretty lame about this stuff right now. Any help would be highly appreciated.
Thanks!
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 01-17-2012, 12:42 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
http://www.bandc.biz/pdfs/SSF-1_Information.pdf
Mine are setup like the diagram at the bottom... schroll down 2nd diagram in line with diode.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-17-2012, 12:57 PM
Brantel's Avatar
Brantel Brantel is offline
New technology is available now that completely replaces the flasher relay with a solid state solution. You can still use the single switch.
http://www.vansairforce.com/communit...84&postcount=6
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-17-2012, 01:05 PM
Did that work for you, Brantel? If so, would you happen to have a wiring diagram?
edit: found the wiring diagrams in the documentation...
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 01-17-2012, 01:52 PM
Brantel's Avatar
Works better than great. And it is not load dependent like the flasher relay.
Old 01-17-2012, 02:01 PM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Ours too. Works like a champ...
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 01-17-2012, 04:36 PM
Default Decisions....decisions
Looks like $40-$45 for the solid state system Brantel suggested, and $28 for the B&C diode and wig-wag module. As mentioned, probably less current draw for the solid state model and a maybe less expensive switch. Neither system looks to be difficult to wire-up.
Could be a wash.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 01-17-2012, 05:26 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Here how I did mine
I did mine 5 yrs ago.
https://picasaweb.google.com/1089952...eat=directlink
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-17-2012, 05:46 PM
Yup... the flashers are available @ NAPA. Why would you want to tie yourself to the wiring and a solid state unit. The flasher is plug and play, and cheap. A Basic Diode, Flasher and a Switch... The diode can be purchased a Radio Shack.
Reiley
VAF# 671
Friend of the RV-1
Old 01-17-2012, 05:50 PM
Brantel's Avatar
Hu?
Wiring is required for both and it can use the same switch.
The SS one works when one bulb burns out, the relay flasher won't.
The SS one works with HIDs, the relay flasher would not when I tried it with HID's.
The SS one works with LEDs, there is not enough current on some LED's to drive the flasher relay. One can add load resistors to the circuit to make it work but that is not efficient.
The SS one won't wear out, at least not any time soon with normal operation. There are tons or reports of the flasher relay giving up the ghost.
The SS one has selectable flash patterns, to change the speed on the flasher relay, you have to perform surgery and change the timing circuit.
The SS one does not require a diode, the flasher relay requires the diode which always runs one side at a lower voltage than the other.
