Old 01-17-2012, 10:47 AM
GTWreck GTWreck is offline
Default Ring terminals with captive nut
I'm working on hooking my engine probes. The CHT thermocouples had an interesting ring terminal attached to it that has a nut welded or pressed onto the terminal ring. I've never seen this before. I can see a use for them in some cases, but I can't seem to find a source for them.
Does anyone know the part number and a place to order them from?
Aaron Sims
RV-10 (2015 Bronze Lindy)
RV-6A (sold)
Home Field: Mallards Landing (GA04)
Locust Grove, GA
Old 01-17-2012, 12:28 PM
larryj larryj is offline
Looks like a PEM nut installed on the ring terminal
http://www.pemnet.com/fastening_prod...tener_new.html
Larry E. James
Bellevue, WA
Husky A1-C
Rocket (under construction)
Old 01-17-2012, 01:03 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
The easiest thing to do is call the manufacturer of the probes/instrument and ask for some spares. They might even send you some for free...
If not, I bet they can give you a part number.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-17-2012, 01:29 PM
aerhed aerhed is offline
You see those a lot on certified probes with PIA slotted 6-32 screws. Sometimes soldered also, depending on wire type. They're kinda old-timey. Supposed to have fabric tubey thing laced over each terminal. Bulky. You could no doubt crimp on new connectors and never know the difference electrically.
Actual repeat offender.
