Old 01-16-2012, 06:04 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default My PMag T fitting for MP
I am making a plan to install the T fitting for my MP for the 2 PMags and curious as to your (VAF community) thoughts on this location for the T fitting. The PMags will connect from the left and right side and the upper piece to the 90 degree AN fitting on the firewall. Wanted to get some opinions before I made the T fitting permanent...
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 01-16-2012, 06:23 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Ryan, this location looks fine to me, but may I suggest a short piece of hose, of the appropriate i.d., slit longitudinally, placed over the engine mount tube. Then tie-wrap the fitting to the hose. I don't think it's a good idea to tie-wrap directly to the tube as it can cut into the tube over time. Just want to make sure you are aware of this.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 01-16-2012, 06:24 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Read some of this...
http://www.vansairforce.com/communit...d+pressure+tee
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-16-2012, 06:48 PM
miyu1975's Avatar
Pat...noted..thanks.
Lifeo... that link on the other log didn't work.
Ryan Allen, CFII
E-170/175
Old 01-16-2012, 07:22 PM
Ironflight's Avatar
VAF Moderator / Line Boy
That location looks fine to me as well - just about anything will work. One thing to think about is that you'll want to disconnect the line whenever you time the P-Mags. Disconnecting a line for a barbed fitting can be a real pain. The hose that is supplied with the P-Mags fits PERFECTLY in the QD static fittings that Stein sells - use one of those on the firewall manifold - or a "T" on the engine mount, where you have the barbed "T" - and it can make your life easy down the road....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-16-2012, 07:29 PM
Default Try This
http://www.vansairforce.com/communit...ad.php?t=80822
Reiley
VAF# 671
Friend of the RV-1
Old 01-16-2012, 08:14 PM
miyu1975's Avatar
Thanks... Paul I will have to look into the QD static lines from Stein. Did you ever get pics up of your recent install?
Ryan Allen, CFII
E-170/175
Old 01-16-2012, 09:28 PM
Ironflight's Avatar
Find an Album of Pictures (with captions) here:
https://picasaweb.google.com/1114071...JCdopzF7f7zWQ#
Paul F. Dye
Old 01-17-2012, 05:14 AM
miyu1975's Avatar
Paul...that link isn't working
Ryan Allen, CFII
E-170/175
Old 01-17-2012, 06:57 AM
Ironflight's Avatar
Try it now
Paul F. Dye
