Old 01-15-2012, 04:31 PM
bret's Avatar
bret bret is offline
Default Fuel vent location?
Finished the wing paint and want to get all the little things finished, looking for suggestions for the tank vent location, I have seen others install the vent closer to the drain but I was thinking of this location, any suggestions?
Old 01-15-2012, 05:13 PM
bkthomps bkthomps is offline
the exhaust heat preventing icing is a key factor in it's factory location
Old 01-15-2012, 06:38 PM
bret's Avatar
Aww, good point, these vents have a screen on the ram air side, and a smaller opening on the back, in the event of ice or bug blockage they will still vent. Even tho I did complete 90% of my IFR training, ( had a family and had to postpone) I am going to stick to a good set of rules that one posted on here, no need to fly into IMC or known icing conditions, no flight ( for me ) is so important that I need to be any where that soon. My (plan) for this machine is day night VFR, Bad weather, stay home. O shoot, no night flight, OK maybe touch and goes......
Old 01-15-2012, 06:45 PM
RV7ator RV7ator is offline
That looks like a dandy way to drain off fuel if you park somewhere with a wing down and tanks near full (or less, depending on slope). That's why Van's has us go to the trouble off routing the drain into the fuse where a big whoop-t-do trap can be located.
John Siebold
Old 01-15-2012, 07:27 PM
APACHE 56 APACHE 56 is offline
I think the Harmon Rocket guys do it this way and I don't recall any complaints from them.
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 01-15-2012, 07:31 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
If you are going to vent near the wing you are better off using a naca type vent like the big iron, preferably slightly aft of the spar. No need for heat to prevent icing, less drag, and you can use very small holes to keep critters out.
Mine is going to be attached to the bottom of the wing intersection fairing.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 01-15-2012, 07:47 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Rocket guys and...
http://www.vansairforce.com/communit...ead.php?t=1062
...some RV-3 builders and others too!
http://www.vansairforce.com/communit...ad.php?t=77849
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 01-15-2012, 08:13 PM
bret's Avatar
Yes I have looked at where the vent in the tank is located, past 90% full, the vent tube is under the fule level, bad design in my eyes, but in any case of vent location, when the fuel expands, where is it going to go, is there enough volume in the fuse vent routing to accomidate this or is it still going to vent, just trying to figure this out,(havent got the fulse kit yet)
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Default Works great
I have done this in my 7, and. Know others as well have. It works,never had any drain out inany situation.
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
Old 01-15-2012, 08:17 PM
bret's Avatar
Cool, where is the location of your vent? Pics?
