Old 01-15-2012, 04:09 PM
GusBiz's Avatar
GusBiz GusBiz is offline
Default Independant PAX Pilot Brakes
Has anyone played with making the Vans Brake system a 4 cable system instead of a two cable system.
Why you may ask?
Because if allows you to place independant pedal distances, for when you are longer in the leg and your Co-pilot is shorted in the leg.
ie if I its comfortable for me, my partner can't even touch the pedals. Not on our aircraft the fuse hasn't even been started but on other aircraft we have sat in.
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
