Old 06-01-2006, 09:44 AM
dwilson dwilson is offline
Default EIS4000 with ammeter shunts???
How does one connect the ammeter shunts on Aero-electric drawings to the EIS-4000?
I am using the dual alternator Z-14 drawing.
There are 2 wires coming off of the shunt and going to the "Load Meter." I assume one of these would go to one of the aux inputs on the EIS, but where does the other one go?
Duane
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 06-01-2006, 03:03 PM
BillC BillC is offline
Duane,
Not sure you can use a shunt with the EIS4000. Looking at their website I only saw hall-effect device. I would check with the manufacturer to make sure!
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 06-01-2006, 04:43 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Hall effect
Originally Posted by dwilson
How does one connect the ammeter shunts on Aero-electric drawings to the EIS-4000? Thanks, Duane
What BillC said. The EIS-4000 is not compatible with a traditional shunt. A hall effect is better in my opinion in that there are no breaks in the feed line you are measuring. It just fees thru the center of the the coil or ring of the hall sensor. Very accurate.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
