01-13-2012, 06:11 PM
Van's 2012 Calendar Service Bulletin Problem
I just completed the mandatory Service Bulletin regarding the 2012 Van's Calendar:
When I finished, I ended up with two January 1st's - one at the beginning of the month and one at the end of the month. Has anyone successfully completed this SB?
I don't think I can handle two New Years Eves in one month  . Also, I believe the Mayan end of the world will still be disrupted  .
Edit: BTW, I found the Sharpie worked much better than the Proseal. I've got two calendars and I did the first with Proseal. Now, I can no longer view January, as the cover is permanently stuck to January. I suspect I still have the same problem with two January 1st's, but cannot confirm.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
01-13-2012, 06:38 PM
I would recommend using Weld-On 10 or perhaps Lord Epoxy that has been tinted black as popular alternatives to ProSeal. But if you must use Proseal you could always dilute it a bit with MEK and "slosh" it around the calendar page to remove the mistake as well. From what I could tell, it should work to eliminate the errant items. If you do this though, you should sell the calendar to someone else and tell them not to worry about January.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
01-13-2012, 09:06 PM
Mandatory?
I'm questioning the legitimacy of Van's making this a mandatory service bulletin. They did not actually build the calendar, and given it's experiential nature - is compliance really enforceable?
Brian S.
Nashville, TN
N104BS RV-10
350 hours
01-13-2012, 09:20 PM
Live the January you want to live, not the one someone else wants you to live.
Stephen
01-13-2012, 09:27 PM
No information there about priming or any kind of surface prep either. Can I use a rattle can primer before prosealing if the SB doesn't specify it? Are whiteout and Sharpie chemically compatible?
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
01-14-2012, 12:02 AM
I'd recommend stop-drilling the remaining "1-number" on the last day of January on the calendar (Wednesday) so the second Jan 1st is removed permanentely. Otherwise we'd crack up due to laughter...
Or maybe the calendar can be fluted so we don't see the remaining 1-number" in a bulge?
There's ofcourse another option: leave the calendar as it is because that would give us an extra building day. Final result: the plane is finished one day earlier
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
01-14-2012, 05:47 AM
No!
I'd cut out the defective calendar sections using a Dremel and install a doubler using posterboard as a template. Then I'd fiberglass a 1 layer patch in place being careful not to add too much weight. Use micro ballons in the West Systems mix. Sand the patch down and use Super Fill on the pinholes. Use your Brother printer to make new calendar labels with the correct date.
Sorry, I've been reworking my upper gear leg fairings and building a "Vetterman" Cowl Exhaust Exit Speed Fairing. I think I absorbed to much acetone last night.
p.s. I'm not an engineer, but somehow this has to be related to the nosegear issue.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
01-14-2012, 06:40 AM
Just sell it
on Feb. 1 and the Mayans will probably never know, they could only look so far ahead or behind anyway.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
01-14-2012, 06:48 AM
Well, as for me, I began to comply with the service bulletin but with so much stuff going-on in my life, I just can't seem to get motivated to complete it. I'm thinking of selling my calendar to someone who can get it finished!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
 RV-9A Firewall Forward
[Engine purchased]
01-14-2012, 06:58 AM
Compliance Issue
I accomplished procedures 1 and 2, but hired out 3 thru 5. As I also did the logbook entries, I think I qualify for the 51% rule, as the paperwork took most of the time (as usual). What do you think?
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
