Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-12-2012, 07:08 PM
SmilingJack's Avatar
Default G3X TFR presentation
Does anyone know why the DC SFRA depicts a RED circle around the 60nm range?
Seems like it should not do that as it is a FREE FLIGHT area and only a speed restriction zone.
Any thoughts?
John Mastro
RV-8
Old 01-12-2012, 07:24 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Not just a speed restriction... also have to take an online course
For flights within the 60nm radius you also have to take the online course from the FAA...
Course Name: ALC-55: Washington DC Special Flight Rules Area (SFRA)
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 01-12-2012, 07:31 PM
Default That makes sense...
I took it a while ago and remember the speed restrictions and flight plan, xpdr, etc...
But, I guess I'll have to retake it as I forgot the importance of the 30-60nm ring.
It would be nice if Garmin made the 60nm ring dashed line instead of solid.
Thanks for the info Stephen.
Regards,
John Mastro
RV-8
Old 01-12-2012, 07:57 PM
mburch's Avatar
mburch mburch is offline
The color of the TFR data on your screen is determined by the data that comes over the air from XM, who gets it from another provider, who gets it from another provider, who gets it from the FAA. Your display unit doesn't know how to do anything other than what it's told. So unfortunately it's not something that's easy to change, even though one might wish it to be otherwise!
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-12-2012, 08:31 PM
Thanks Matt!
Too bad "XM" can't reprogram.
I have to say, now that I am flying the airplane on long legs I'm enjoying the G3X and all the options.
Now we just have to get that ADS-B solution
John Mastro
RV-8
Old 01-13-2012, 04:23 AM
Capflyer's Avatar
Capflyer Capflyer is offline
The 60nm ring as mentioned is the boundary where you are required to have taken the SFRA course. It is depicted on the TAC and Sectional.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
