Old 01-07-2012, 01:24 PM
jbagley's Avatar
jbagley jbagley is offline
Default Tool conundrum - benchtop bandsaw recomendations?
So, I can't be the first builder to have this problem...
I have a flying RV at the airport in a hangar where the majority of my tools are and I have an RV under construction at home. I have slowly been moving my smaller tools into individual tool boxes for easy transportation. But, I can't see dragging drill presses and band saws around...
I find myself doing some work at home and some at the hangar (where I have more space).
Would like to buy an inexpensive drill press and band saw. Any recommendations in the $100-$300 range for a bench top band saw and/or drill press? Most of the online reviews for these lower end units appear to be woodworkers.
Thanks!
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 01-07-2012, 02:50 PM
Alex Alex is offline
Default Try Craigslist too
I was able to get a Grizzly G0555 for $200 by monitoring Craigslist and waiting for a good deal. It's been great, and much nicer than a tabletop model.
Alex Roup
RV-12 (empennage) #120407
Northern VA
Old 01-07-2012, 02:54 PM
fatherson fatherson is offline
I have this DELTA BS100 Shopmaster, and find it works great. I replaced the cheap supplied blade with a higher quality 14-tpi metalworking blade, which cuts aluminum like butter.
Stephen
Old 01-07-2012, 03:13 PM
Craig's Avatar
Craig Craig is offline
I am happy with the line of Ryobi benchtop tools that I bought at Home Depot.
Band saw, drill press, belt sander.
Each cost just over a hundred dollars.
Craig MacArthur
RV-8 TMXIO360
Old 01-07-2012, 03:25 PM
ppilotmike's Avatar
Default Any bench-top will do...
I think any bench-top band saw will work pretty well with a decent blade in place. I have a cheapo from the depot and it works just fine with aluminum. Take it slower with the big stuff though..
Mike Rettig
VAF Dues Current
Old 01-07-2012, 04:39 PM
rv9aviator rv9aviator is offline
The table top one I bought from Grizzly was awful. The blades were an odd size too. I don't think they sell that model any more which is good.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 01-07-2012, 06:07 PM
pilot2512 pilot2512 is offline
I have bought all my power tools from CPO outlet. They sell reconditioned tools with a warranty. Haven't had any problems and they shipped quickly. I got a 9" band saw for $89 and put a metal cutting blade on it.
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 01-07-2012, 06:12 PM
jpharrell jpharrell is offline
Default 10-inch Craftsman
I have been happy with the 10-inch Craftsman I bought about two years ago. It ran about $200. Since I replaced the blade with a bi-metal 14-tpi from Haltbar Sagen it cuts aluminum very well. Just don't cut steel or the blade will dull quickly.
John Harrell
Building RV7A fuselage, finishing kit ordered
http://www.johnsrv7a.wordpress.com
Old 01-07-2012, 06:55 PM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Home Depot
Ditto for me.
Old 01-09-2012, 05:55 AM
I received the 9" craftsman bandsaw as a gift. It has seen no use on the RV to date. It is basically useless. I think the 10" model is OK, but the 9" is just cheap. The frame flexes so bad that you can't put tension on the blade without it wondering off the reel. I don't even use it for cutting wood. Plus the blade is an odd-ball size that no one carries.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
