Old 01-06-2012, 12:36 PM
PaulR PaulR is offline
Default Draining water from Fuselage
Most if not all, of the airplanes I've ever flown have a small drain hole rearward (tricycle) of each bulkhead in the fuselage. I haven't seen anything in the plans about this though I may have missed it. I did a quick search and found a couple of threads that talk about it a little but nothing definitive.
So, I'm thinking just aft of the each bulkhead and probably also in the airbox. (carbed) Maybe an 1/8 or 3/16 hole to allow water to leave. What does everyone else do?
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 01-06-2012, 02:17 PM
terrye terrye is offline
Default Draining water from wings
I haven't seen anything in the builders instructions about water drains either. And what about the wings? Are these self draining because of the dihederal angle. I know there are fuselage drains in my C-150 as PaulR has said, I also notice a few drain holes in the bottom wing skins near the aft spar.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 01-06-2012, 04:17 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
In canada we require these holes in order to pass the final inspection. I drill a 1/8 hole in the low point of the fuselage in every second rib bay.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 01-06-2012, 05:36 PM
kevinh's Avatar
kevinh kevinh is offline
There is a small note in the plans about this. Just as you describe a #30 hole just aft of each fuse bulkhead.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 01-06-2012, 05:43 PM
Walt's Avatar
Walt Walt is offline
Troy has it right,
Plus... I always put a hole where the fuel pump resides so in case there is a leak the fuel has a path to drain overboard and not accumulate
Don't forget the rudder fairing and inlet airbox as well.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-06-2012, 11:27 PM
Flying Scotsman Flying Scotsman is offline
There is???? I don't recall seeing this, but then again, I've parted company with the plans a while back once I got to FF stuff...this is a good topic and I'm very inrerested to know if there are any suggestions here...
Thanks...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 01-07-2012, 06:59 PM
Default 1/8"???
Walt,
Is a no. 30 or 1/8" big enough? Seems like the surface tension on water might be to great to allow it to drain. Good idea about the boost pump. I wouldn't have thought about that location.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Old 01-07-2012, 07:05 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Paul, find some scrap aluminum and make a depression to hold water (actually it could be a can).
Fill it with a certain level of water. Maybe 1 inch. Drill a small hole (perhaps 1/16"). If it does not drain (surface tension/head issues) drill a larger hole.
Continue with less water depth until you determine what size hole is needed for the depth water you want to drain. Obviously the hole has to be larger for shallower water depths.
I will have to measure what I did but a wag is around 3/16" hole.
Old 01-07-2012, 07:41 PM
bruceh's Avatar
bruceh bruceh is online now
The only drainage holes I've seen on the plans for the RV-9A are on DWG 7, Note 3:
Add 1/4" dia. drainage hole to R-911 (Rudder Bottom) at low point when the airplane is in ground attitude.
I haven't drilled any other drainage holes in the fuselage. If there is direction in the plans to do that, I would like to see it.
It is things like this that would make having the plans in digital form so much better for searching... Imagine being able to "google" the preview plans and build instructions.
Bruce Hill
2020 VAF donator
Old 01-07-2012, 07:49 PM
scard's Avatar
scard scard is offline
Originally Posted by PaulR View Post
Walt,
I agree, #30 and 1/8" is too small in my real world experience. Just a little bit of dust collection compounds the problem of clean surface tension. I opened mine up to almost 3/16" after finding non-draining water.
Scott Card
CMW E-Lift
