05-31-2006, 07:09 AM
First flight runway length...
In the Preview Plans under "Flight Testing" it is suggested that the first flight be conducted on a runway at least 3000' in length. The closest 3000' runway to my home is 1 1/2 hours away. The field where I current fly out of is 1/2 hour away. It has a 2000' runway with a 500' grass overrun.
If I decide to build an RV I could do most of the construction in my 3-car garage, but final assembly would have to be at the field. I'm not sure if I'd ever finish if I had to drive 1 1/2 hours to the hangar while doing the final construction.
Two questions: What percentage of the construction has to be done at the field? How many hours? And would you consider first flight and subsequent flight testing on a 2000' foot runway with a 500' grass overrun area?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
05-31-2006, 07:33 AM
Moderator/Tech Counselor
I flew my 7A out of our private grass strip (1700 ft), but my first two landings were done at longer strips (4000 +). I wanted to get comfortable with landing before attempting a landing at home. We have the luxury of a larger airport two miles away, so I had options if trouble arose.
Unless you are very competent with flying, especially HP aircraft (RV's in particular), I would opt for a larger field for at least the initial flight.
You should be able to get the plane completed at home, remove the wings, and trailer the plane to the longer airport. That would be the best, and safest, plan. It would be much more inconvenient if you should have to do an emergency, rushed, landing back to a very short field and schmuck up your new plane.
JMHO,
Roberta
05-31-2006, 07:44 AM
VAF Moderator / Line Boy
Makes me Nervous...
Michael,
There is no doubt that a 2000' strip would be a great place to operate from in the long run, but it would make me nervous to do a first flight in an aircraft off that length unless I had lots of time in the same type. Any RV will be well off the ground in that distance on take-off, but you probably wouldn't want to make your first landing (in type) on a place that doesn't give you a large margin of error for float.
I obviously don't know your piloting background, but I'd say that while this would be possible if you accumulated some time in type before you took yours up (and had a good handle on landing it short), this doesn't give you much margin for contingencies. I have seen at least one case where a person lost a homebuilt on the first flight simply because they weren't prepared for how it flew, and there was no margin for error.
I agree that it would be hard to commute a long distance for building. But if you have a three car garage, you could basically finish the plane at home, take it apart, trailer it to a better field, and in a very short time have it ready to fly.
Only one opinion - I'm sure you'll get more!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-31-2006, 07:59 AM
Seatac?
I can't add anything to the great answers you've gotten so far.
Probably a dumb question, but could you get a hangar at seatac for a month for final assembly and early flight testing?
Edit: Never mind - just looked at it on Google maps. No GA that I can see.
05-31-2006, 08:19 AM
Seatac / Paine Field...
SeaTac is in the middle of a metropolitan area and is in class B airspace. How appropriate would it be to try and flight test at such an airport. I didn't think you could do flight testing over congested areas.
Paine field in Everett might be a possibility, but it is also over congested area, but much less so that Seatac. It is also not in class B airpsace. It is the airport that I was thinking of when I said 1 1/2 hours away. It is about 30 miles away, but traffic here in Seattle is horrible and I live about 10 miles from a freeway, so it can take awhile.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
05-31-2006, 08:34 AM
Michael,
If I were you I'd find a DAR in your area (a reputable one) and find out exactly which airports are approved for first flights, and roughly what you can expect as far as your Phase One restricted area is concerned. That'll give you a pretty clear idea of where you can and cannot base the airplane for Phase One.
Also, my 2 cents which echo previous replies: ANYTHING that adds even small amounts of stress, pressure, or constraints to a flight -- whether it's a short runway, obstacles, the condition of a runway, etc. -- is not a good thing. For your first flight and Phase One, try to remove as many variables as possible. Would 2000' be enough for your first landing? It should be. But if you have a CHOICE and can opt for a bigger strip (with fire/rescue facilities if possible), all the better imho.
Dan Checkoway RV-7
05-31-2006, 09:03 AM
Hi Michael:
I would say that you're such a long way from flying I would just worry about building now. All those little details seem to work themselves out.
We have a local -9A builder that's using builder's assistance at an airport that's about 1.5 hrs away. This is *real* builder's assistance...not the type where you drop the plane off and stop in every other weekend to help out while someone else builds your airplane.
He borrowed a camper trailer and got permission to keep it at the airport. That's where he stays during the week while he works on the plane (he's retired so he can do that). If you want to fly your project bad enough you can make it happen.
I believe it was the infamous Rosie that said he had his -6A flying in just a couple of weeks after taking it to the airport...so it *can* be done. In the time I've been building I've watched many people haul their projects to the airport, just for progress to slow to a standstill because it's no longer convenient to work on it. I hope to keep mine in my garage until there's absolutely nothing else I can do at the house.
Best of luck...and stop dreaming! Start doing.
05-31-2006, 09:10 AM
Seattle Area Options
Michael, one of the downsides of our area is that we just don't seem to have the nice variety of airports around that other areas do. I'm over in Hansville and base my RV at Tacoma Narrows - 5000 x 150 of good pavement, friendly tower, and sparsely populated areas nearby. Of course, there is a lot of that cold Puget Sound water nearby too, which was on my mind as I departed Rwy 17 on 9/8/04 for first flight.
Paine would be one decent option for you; perhaps Auburn (not sure of that strip's dimensions or services). Harvey Field in Snohomish a little short and narrow for a first RV flight, IMHO. BFI would be bad due to overlying SEA Class B, heavy mixed traffic, and dense population; Renton has similar issues though not quite as bad; SEA itself would be out of the question
TIW or Bremerton would be great but both are across the Sound and way too far from your home. Also, finding hangar space ANYWHERE around here seems to be very difficult, at least for anyone who is not Bill Gates.
****, maybe you're better off going over the mountains to Ellensburg ?
Whatever you choose, with a 3 car garage you can get it assembled, checked out, and then trailer to the airport and do final assembly and airworthiness inspection there. DO AS MUCH AS YOU CAN BEFORE YOU GO TO THE AIRPORT - when I moved the bird to TIW it got A LOT harder to get things done, and took way more time (I am 65 minutes from home to TIW, about 45 from my office in Poulsbo, but either way it is a long haul; best is if I have a hearing or something in Tacoma and can then hit the airport on the way home).
Good luck - and whatever you do, don't let this issue stop you from taking the plunge and building.
05-31-2006, 09:58 AM
Can you get an experienced RV pilot to do the initial test flight at the small strip? After a flight or two, it could be flown to a larger airport for your initial flights.
My first flight was off a 2900' grass strip. In hindsight, the length caused me some distraction. But had I been a little more RV experienced, it would have been OK.
Bryan
Bryan
Houston
05-31-2006, 10:31 AM
You are getting good advice.
Go for the longer runway, do as much at home as possible. It took me 3 months to do final assembly of my aircraft in a hangar once it was painted. The hangar was 15 minutes from home, and the airport had a couple of long runways (up to 4800 feet).
Although you will probably never need the extra length, why add another risk or worry to your first flights? Believe me, that first flight is stressfull enough without worrying about the airport as well.
Add the extra commute time to your building time and you'll find that it's not much in percentage. Move closer when you are comfortable.
Safety is all about making good decisions, and having a backup plan for every failure scenario. The most likely scenario is an engine failure on takeoff... that's where the extra runway is useful-- backtrack for maximum length as well.
It's handy on landings as well, but the backup plan for a botched approach is a go-around. A go-around is a sign of good pilot decision making.
Vern Little
