Old 01-08-2012, 04:18 PM
RV7Grinner RV7Grinner is offline
Default Temperature control
As one of the two recent failures referenced by John above, I am convinced that my failure last week was temperature related. I had just dropped off a passenger with a short shutdown followed by a hot start and taxi for takeoff. Failure (apparent loss of timing) occurred at start of takeoff role.
So, after replacement of "temperature dicolored circuit board", is there a science to pointing the blast tube at the right spot on the Pmag? Thanks for the help.
Bruce McGowan
Old 01-08-2012, 05:11 PM
RV8R999 RV8R999 is offline
I have 1 P-mag and a slick. I can't even begin to count the number of hot-turn-arounds I've done in the last 200 hours without any ignition issues at all (knock on wood) most of those during 95 OAT days in Southern Florida. I do have 3/4" blast tubes. FWIW
Old 01-08-2012, 05:47 PM
N941WR's Avatar
N941WR N941WR is offline
Bruce McGowan
Bruce, please contact me off list regarding your failure.
Thanks!
bill (at) repucci.com
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-08-2012, 05:53 PM
N941WR's Avatar
Dan,
Family issues came up this weekend and I didn?t even make it to the airport. Rain is expected for most of this week, so we may have to wait until next weekend for a temperature test.
Bill
Bill R.
SC86 - Easley, SC
Old 01-08-2012, 06:55 PM
Brantel's Avatar
Brantel Brantel is offline
Originally Posted by RV7ator View Post
So let's have a show of hands: who has had, or has first-hand knowledge of, P-mag problems in the last three years? Electrical or mechanical difficulties? Was SB3 incorporated? Blast tube or no?
John Siebold
Absolutely no problems with mine. I love it! Latest design and firmware.
Installed per the directions with a blast tube blasting on the fins of the Pmag.
My taddle tale sticker has never tripped and I see 400F on most climb outs.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-03-2016, 10:51 AM
Bad Sheila's Avatar
Bad Sheila Bad Sheila is offline
Talking E-Mag Blast Tubes
I have just installed 2 E-Mags on my RV6 with O-320 and I am looking for the best blast tubes to use and a way to install them. Any pics and suggestions. Once I get these on I can fly.
Tony
Old 02-03-2016, 02:48 PM
eddieseve eddieseve is offline
I have two P-Mags in my RV7, 114 series, purchased second hand on this site, blast tubes are installed, latest software timing upgrade not done.
Over Christmas we did a series of joy flights for our staff, 1.5 hours of start stop activity in 37 deg C (98F) heat and had no issues at all, I know we are crazy but our staff loved it, bumps and all.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 02-03-2016, 04:30 PM
Richard Connell Richard Connell is offline
One more data point. I've got a sensor glued to the outside top of my left PMAG.
In flight at cruise altitudes it's always pretty cool around 120-140F.
On shutdown the temperatures rise quickly.
Here's the hottest flight I can remember since installing the PMAG. It also involved a quick turnaround. OAT on ground around 40C.
On startup the Temp was around 200F. Didn't really drop below 175F until TOC.
Standard blast tube install.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-03-2016, 06:25 PM
N941WR's Avatar
FYI - The internal temperature probes on the P-mags are not calibrated, thus any temperature displayed by the EICommander or using the EICAD program should be taken with a block of salt.
Tony
I hope you have P-mags and not E-mags installed. Emag is the company and they used to sell E-mags which where the same as the P-mag, less the internal generator.
Please get them in for the version 40 upgrade. It is critical, if you have toggle switches as it is a sure bet you will start the engine with one grounded and one ungrounded, which will reset the grounded mag.
(This upgrade will also help with starting as it sets the timing to 4 degrees after TDC when below 200 RPM. Above 200 RPM and the timing goes to 19.6* BTC at low RPM settings.)
Bill R.
SC86 - Easley, SC
Old 02-03-2016, 09:36 PM
I have the ACS key switch with the jumper removed, so both Mags become live at the same time
I have for the last year had the PMags timed to fire at approximately 4 degrees after TDC to ensure no kick back etc.
I initially ran the PMags with the timing at TDC but did experience the occasional kick back, since the timing change I have had no more kick backs and cannot notice any difference in performance, although I am seeing cooler CHTs as would be expected.
I am also running with the PMag jumper installed.
I would love to get the upgrade, but being in Sydney Australia there would be quite a substantial lag involved in shipping and them getting the units returned.
When I bought the two units, I contacted Brad and sent him the serial number information, he stated that they should be fine the way they are currently wired.
If only there was a way for end users to do their own software updates ???
Cheers
Eddie Seve
Sydney Australia
1100 hrs Feb 2020
