Hi, Jim.
I am not an engine expert, I hope one of them will reply soon.
275 is low for an engine that is being broken in.
I would be looking at my engine monitor to make sure that it is reading the temp correctly. Check the calibration on the monitor or get someone with a portable temp. reader to check to make sure that what you see is what you are getting.
While I was breaking in my IO-320 my temp were close to 400 most of the time. I would not start leaning until I had a handle on the temp. If your engine monitor is off by 150 degrees you won't want to try to increase the temp for the break in.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
