Old 01-05-2012, 01:03 PM
RobinHou RobinHou is offline
Default QB Interior Prep for Paint
I am building a QB RV-7A. Much had been discussed re painting the interior. I have decided to go with Rust-oleum "Professional" High Performance Enamel, Light Machine Gray, #7581.
My interior has been primed by the QB shop. In my research, I have found builders using alcohol, acetone and MEK to clean the interior before paint. I tried acetone last night, and it removed the Vans wash primer right off. Given acetone took the wash primer off so easily, I don't think MEK would leave the wash primer intact.
So, I am seeking QB builders' experience on how best to prepare the Vans wash primer for paint:
1. Does alcohol leave wash primer intact and yet do a good enough job to clean off grease and oil for paint?
2. What else did you do short of removing wash primer and re-prim before paint?
Thanks in advance, and Happy New Year!
Robin
Old 01-05-2012, 01:44 PM
mike newall's Avatar
mike newall mike newall is offline
Red Scotchbrite all over, vacuum out, go over with Panel Wipe, a spirit based degreaser available from paint suppliers - removes grease and silicone deposits but doesn't affect the wash primer.
Shoot some etch - doesn't need to be much as the wash primer has done most of the work.
Shoot the topcoat.
Move on..........
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 01-05-2012, 06:33 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Cleaning primer for paint
The tried and true Stits instruction is VM&P Naptha, also known as Coleman Lantern fuel and will not remove wash primer. It works perfectly on my three Stits tube and fabric projects. It is available everywhere .
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
