Old 01-05-2012, 11:56 AM
John Courte John Courte is offline
Default FWF zip ties and wire wrap.
The area under the cowling seems like a hellish box of heat and wind.
Are zip ties and plastic spiral wire wrap under there OK or will they become brittle and break? Is there a special grade to use? What are best practices for securing wiring and hoses to intake tubes and engine mount?
cheers,
-John
RV-7 N313TD
SOLD 7/2/2020
Old 01-05-2012, 11:59 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
High temp Zip ties are available and should be used.
Stein sells them as well as Mc master carr
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 01-05-2012, 12:08 PM
longranger's Avatar
I used kevlar lacing cord. (Helps to have a buddy who is an electrician for Lockheed...)
RV-7 TU 904KM (reserved)
Construction Log
Old 01-05-2012, 06:41 PM
aerhed aerhed is offline
The white spiral is usually polyeth. It drips pretty good when you heat it. Your gonna find everyone on here favoring a bunch of Adel clamps & judicious use of Ty=raps.
Actual repeat offender.
Old 01-05-2012, 07:10 PM
Greg Arehart's Avatar
I've used the spiral wrap to keep wires bundled FWF, but use adel clamps and occasionally zip ties to attach things to the engine mount etc. The white stuff does get soft and deform if it's too close to a heat source.
greg
Greg Arehart
N 7965A
Old 01-05-2012, 07:21 PM
jrs14855 jrs14855 is offline
Default ties
Stein did a nice article on this subject in Kitplanes recently.
Old 01-05-2012, 07:29 PM
Captain Avgas Captain Avgas is offline
All of my FWF zip ties are high temperature Tefzel (they're blue colour). Stein sells them. They're the go.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 01-05-2012, 09:36 PM
Wayne Gillispie Wayne Gillispie is offline
I used tefzel, hylar and regular ties depending on location. I also used orange silicone tape and adel clamps. Any material closer than 4-5" from exhaust should be protected. Local airflow will affect material temps. Don't forget cowl heat shield. My alternator surface temp exceeded 300F due to cyl #1 exhaust pipe radiant heat. I will be installing a shield here. I have temp labels on everything including brake calipers. The real test will be this summer. Some spiral wrap 4" away from exh started melting near cowl outlet. This is during 30-50F surface temps in phase 1.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-05-2012, 10:34 PM
PCHunt PCHunt is offline
What is a Temp Label? I can picture something that changes color with temp, and you can read it later
Part numbers and sources appreciated!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 01-05-2012, 11:51 PM
Lars Lars is offline
Not only that, Stein's are competitively priced. I tried sourcing them elsewhere since we buy them by the truckload where I work. Not enough savings, and too large a minimum order, to make it worth the bother.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
