01-05-2012, 10:13 AM
Tachometer question
I'm new to engine side stuff so I have a question regarding tachometer reading. I'm wondering if I should get a tach transducer such as the one vans sells, or should I wire my EMS to the p-leads of the mags to read engine RPM? Here is what I'm working with:
Skyview system
Lycoming 6cyl
2 slick mags but might eventually upgrade to 1 or 2 p-mags
The Skyview installation manual seems to indicate I can use either a dedicated transducer or hook to p-leads but I'm unsure if one is better than the other for my situation.
Brian Unrein
RV10 N42BU 900+ hours!
First flight 6-16-12
https://N42BU.com
01-05-2012, 11:08 AM
Senior Curmudgeon
If you do the Vans transducer, it will be independent of what ever ignition system you end up with, no reconfiguring if you change to a Pmag or Lightspeed etc.
If you do use the Vans unit, it is an 8 pulse, but runs at half engine speed.
I have no idea as to the life expectancy of the Vans transducer.
Easiest for sure is to just hook up to the "P" lead.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-05-2012, 11:24 AM
Tachometer from Plead
Brian,
The MGL tachometer ( which I have) does not work well from a P-lead signal. Rainer confirmed that an engine driven signal generator would yield more stable results. I can't say about any other brand of tach/efis, but the MGL unit is programmable to accommodate varying signal outputs per revolution. Ie, I assume an eight pulse or 4 pulse generator could be programmed to work on a six cyl engine.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
01-05-2012, 11:40 AM
Senior Curmudgeon
The number of pulses have nothing to do with the number of cylinders, it is something referenced to the rotation of the crankshaft.
But, the drive on the accessory case runs at half engine speed.
I am using Vans pulse generator/tach transducer or whatever you call it on my 540.
The GRT unit is programmable to a wide input in pulse/crank revolution range.
Mike Starkey
VAF 909
Rv-10, N210LM.
01-05-2012, 11:45 AM
P-leads.
Brian, we had a Van's transducer on our -6 and it went maybe 300 hours and broke, so we replaced it.
My buddy had a D-180 in his -4 and used the P-lead pickup....that was 5 years ago and still running strong. Since the P-lead pickup has no moving parts and the transducer does, it's my pick as well.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
01-05-2012, 12:22 PM
Thanks for the feedback everyone. I think I'll try to go with the p-lead route and hopefully I can get accurate readings and can buy the AFS hall sensor mentioned by Rob as an ace in the hole if necessary.
One of the posts mentioned using shielded wire. Any merit to this?
Brian Unrein
https://N42BU.com
01-05-2012, 01:33 PM
You should use shielded wires. The P-Lead signal is a high power signal which could interfere other systems like audio. But ground the shield only on one side.
Kai
flying RV-9a, O-320, G3X Touch
a father&son project
01-05-2012, 03:02 PM
VAF Moderator / Line Boy
I've gone the P-Lead route with the Dynon D-180, GRT EIS, and Garmin G3X (the G3X is connected to P-Mags, the other two to Slicks). All work just great!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-10-2012, 08:48 AM
To echo an earlier response, I also have found the Van's transducer as unreliable. I replaced the first at 50 hours and the second just failed at 350 hours. I just switched to the Flight Data Systems tac using the mag signal at for not much more than the transducer cost from Vans.
Scott- 2020 donation
New RV-7A N579RV, only 80 hours now without 2020 fly-in destinations
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
