Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #71
Old 03-03-2012, 03:37 PM
paul mosher
Posts: n/a
Default read a book
prop governor. look it up.
Old 03-03-2012, 03:41 PM
Moura Moura is offline
Thank you Paul.
Old 03-03-2012, 05:53 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Originally Posted by Moura View Post
Another stupid question, if I want To slow down in circuit and move blue knob all the way forward, the engine's rpm will go up. Can it in any way damage the engine due to over reving? Same would apply in formation in a dive!
You don't have to move it all the way forward. It still acts like a brake. In fact, if you move it forward too soon, it is like quick shifting into lower gear. Throws you towards the panel, and doesn't do well for the engine either. Just push all the way in on short final, when power is pulled back. I'd just usually leave mine, at the 2350 cruise setting. You'll only notice that the blue knob isn't full forward, if you do a go-around or touch and go. You'll notice a definate decrease in power.
Old 03-03-2012, 10:14 PM
Thank you L. But I was wondering what would be a reasonable / aceptable RPM in such a situation. Max. Take off rpm? Or could we go higher?
Old 03-03-2012, 10:25 PM
PerfTech's Avatar
PerfTech PerfTech is offline
The max is set by the prop manufacturer, most Hartzell or Whirlwind compact is 2700 rpm red line. Allan
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-03-2012, 11:17 PM
paul mosher
Posts: n/a
Default gov
actually prop rpm is restricted by prop manufacturer. Exceed rpm limits and it is a mandatory overhaul.
Old 03-04-2012, 02:59 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default Max RPM
Also, Lycoming engine O-320/O-360 Max rpm is usually 2700, therefore many prop designs are same.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-06-2012, 08:32 AM
smokyray's Avatar
smokyray smokyray is offline
Default Not so fast...
Not quite. 2700 Max RPM on C/S props is correct for most manufacturers recommendations for certified applications and has carried over on experimental props sold to be installed on Lycomings. Being an IA I'm sure you know once you paste "experimental" on your type certificate, all bets are off. You don't have mandatory limits on anything per say, except your conscience, your posterior and the approved limits/maneuvers posted in the logbook during the test phase. If you follow certified standards and limits for your RV experimental airplane's engine/prop, good on ya. Years of testing, NTSB investigations and lawsuits have set the ultra-conservative limits on most parts sold by major aircraft parts companies. They do however perform very well beyond posted limits...
Even Hartzell likes racing airplanes and their custom made props for Dave Anders, the Reno Lancair Legacies and others have higher RPM limits (2900-3200) and were built specifically to run at higher RPM's. How are they different form a stock Hartzell? Call Kevin Karam at Hartzell, he'll tell ya. Craig Catto's background is Reno racing. His props come into their own around 2850 and "posted limits" up to 3200 for my 2 blade. Lycoming's limits running above 2700? That's another discussion for another day. Ask Mahlon, he's on the site.
FYI...
V/R
Smokey
Old 03-06-2012, 10:43 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Originally Posted by rockwoodrv9 View Post
Does the extra knob add that much workload for a low time pilot?
No....
I plan to go with a fuel injected engine to reduce the leaning needs and chance of error and engine repairs.
I don't see how fuel injection would in any way reduce the leaning needs in a noticeable way
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 03-06-2012, 05:26 PM
gasman gasman is offline
What is the maximum and minimum pitch of a c/s prop on a RV7 180hp?
Sensenich is fixed at 85 inches.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
