Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #61
Old 03-01-2012, 02:41 PM
ao.frog ao.frog is offline
Default I was just...
.... poking you guys...
(with my comment automatic vs manual transmission)
As already mentioned, I bet this post is just to poke us...
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 03-01-2012, 08:06 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default HP=TxR
Since HP=Torque X RPM, I like to think of the blue and black knobs as 2 ways to add or subtract power, together or individually...
Darn handy and works every time it's tried...
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 03-02-2012, 12:43 AM
trackdom trackdom is offline
In my opinion, Craig Catto, although they're really composite but the most bang for the buck.
Best,
Thanks to you
rv8
First flight february 11 th 2016 , delightfull....
Old 03-02-2012, 01:58 AM
Sig600 Sig600 is offline
Constant speed prop just gives you some extra versatility. Depends on the operator if that is worth the cost. To each their own.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 03-02-2012, 07:21 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default It's really simple.
Do you want great performance at a lower cost, or do you want maximum performance and are willing to pay the difference. Excellent results either way.
William Slaughter
Houston, TX
RV-8QB
Old 03-02-2012, 12:47 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Flying out of mountain airports the CS prop can be VERY useful.
Old 03-03-2012, 02:25 PM
Moura Moura is offline
Default Stupid question
What setting will slow down an airplane with CD, blue knob all the way forward or all the way back?
Old 03-03-2012, 03:02 PM
Mel's Avatar
Mel Mel is offline
Blue knob forward results in fine pitch and maximum drag.
Blue knob pulled back results in coarse pitch and max glide.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default C/S control
C/S Prop control:
Forward: Flatens the pitch for take off, climb or slowing.
Back/out: Increases the pitch for high speed cruise/extended glide.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-03-2012, 03:34 PM
Another stupid question, if I want To slow down in circuit and move blue knob all the way forward, the engine's rpm will go up. Can it in any way damage the engine due to over reving? Same would apply in formation in a dive!
