Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #51
Old 03-01-2012, 09:44 AM
paul mosher
Posts: n/a
Default Prop
C/S use is not a big deal. Look at all the extra knobs and switches people add to their airplanes with the EFIS systems they install.
Old 03-01-2012, 09:48 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Default C/S or F/P
Originally Posted by Flyguytki View Post
Again personal preference, I would rather have a manual transmission over automatic any day. But that right theres proves the point. It all what you want, if you want simple, you cant get much more simple than one lever for power, push forward go fast pull back slow down.
-david
Manual verses automatic isn't an accurate comparison. A far more accurate comparison would be a high tech constant velocity, infinitely adjustable automatic transmission verses a manual trans that is stuck in one gear for life. Allan
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-01-2012, 10:45 AM
Mel's Avatar
Mel Mel is offline
Default I've heard this ONE too many times!
Comparing a fixed pitch prop to a manual transmission stuck in one gear is also not an accurate comparison.
If that were "apples-to-apples", there would be many cars running around with a "one-gear" transmission. Only place I've seen this is on the drag-strip.
There are MANY airplanes flying just fine with F/P props.
When is the last time you saw a car on the road with a one-gear transmission?
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-01-2012, 11:47 AM
LeeM_2000's Avatar
LeeM_2000 LeeM_2000 is offline
Talking Does this count?
It has a fixed pitch prop.
RV-7
In progress...
Old 03-01-2012, 12:38 PM
paul mosher
Posts: n/a
Default aerocar
Yes it does. And it's neither a good car or a good airplane.
Old 03-01-2012, 01:03 PM
Mel's Avatar
Mel Mel is offline
Default DO YOUR RESEARCH GUYS!
This car did NOT drive on the road with a single speed transmission!
Old 03-01-2012, 01:38 PM
LeeM_2000's Avatar
No, but it drove on the road with a fixed-pitch prop. I thought these were one in the same.
It had a 3-speed on the floor for driving the wheels. That's just like having a constant speed prop.
RV-7
In progress...
Old 03-01-2012, 01:49 PM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default Car Transmission analogy.
Mel is correct. The car trans analogy is flawed in showing a comparison between a F/P vs. C/S.
Fixed pitch: $ lower entry price; low maintenance; no mechanical rebuild needed; lighter weight; no loss in top speed.
Constant speed prop does have the advantage of helping to move the CG forward for a more usable useful load, depending on mission. Also C/S has the advantages of a climb prop at slower airspeeds, therefore allowing shorter takeoffs and climb capability.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-01-2012, 01:51 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Exclamation Air is a Compressible Fluid
You guys are off in Never-Never Land.
There's LOTS of difference between turning a propeller (either CS or FP) in a compressible fluid and driving a tire on a paved road.
(Different way of saying that Mel is right again.)
Reminds me of a debate by a buddy who challenged a so-called expert on model airplane propellers after the "s-c e" wrote an article in the AMA (Academy of Model Aeronautics) magazine.
Put your thinking caps on.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Last edited by rv7boy : 03-01-2012 at 02:40 PM. Reason: Added the "Mel" parenthesis.
Old 03-01-2012, 02:34 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Where I work, we're building a car with a single gear fixed transmission and no clutch.
The trick is to use an electric motor that produces 100% torque at 0 RPM
