Old 01-03-2012, 10:25 PM
Flying Scotsman Flying Scotsman is offline
Default Aveo Ultra Embedded Pos/Strobes question
Anyone install the Aveo embedded wingtip position/strobe LEDs? Looking for advice on wiring them...info from the company says "use shielded wire", but a bit more info would be useful .
Specifically...does the sync line need to be shielded as well, and what's the best way to use the shield itself (as ground return, or separately grounded back at the firewall grounding block)?
Any advice/experience would be most appreciated!
TIA
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 01-03-2012, 11:32 PM
craigvince's Avatar
craigvince craigvince is offline
We are an Aveo Authorized Installation Center (AIC). Yes, we have installed the Ultra Embedded, and yes, we use shielded wire for the main feeds, but there isn't any significant benefit to using shielded wire for the sync wire, which only goes from light to light.
Old 01-03-2012, 11:59 PM
Thanks, Craig! Probably be easiest to just use 4-wire shielded to pull it through the conduit, keep it neat, etc. Any recommendation on grounding the shield? I was planning on pigtailing it to wire, joining all three wires (L, R, Tail) to a single wire and running that to the grounding block on the firewall...
Santa Clarita, CA
#8,000
Old 01-04-2012, 12:37 AM
craigvince's Avatar
Default grounding shield
I typically ground the shield at the front end (grounding block), but leave it open at the other end.
Old 01-04-2012, 01:51 AM
beav's Avatar
beav beav is offline
The install manual doesn't mention anything about using shielded wires:
http://www.aveoengineering.com/downl...raEmbedded.pdf
Where did you hear that they recommend using shielded wires?
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 01-04-2012, 07:13 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Not needed
I've been running the 6 in 1 landing/taxi lights with the embedded pos/strobes since July. These were retrofits and the original wiring was used from my previous lights. I did not use shielded wire and locally grounded everything.
The lights are absolutely SILENT!!!!! I do recommend using the sync wire for the strobes.
I fly at night often and the AVEO landing/taxi lights put out tremendous amounts of light.
Let me know if you have any other questions.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 01-04-2012, 09:11 AM
Aveo.
Q: What cable should I use for installing the lights?
A: For our light installations we recommended the use of shielded wire.
http://www.aveoengineering.com/suppo...AQ/index.php#7
(also via email, but some of the info was lost in translation, as they are a Czech company ).
Santa Clarita, CA
#8,000
Old 01-04-2012, 03:42 PM
beav's Avatar
That's an unfortunate thing to leave out of the install manual. Since I've heard others have had success without that, I don't think I'll replace the wire unless I have a problem. Since I ran a ground wire (instead of grounding locally at the wingtip), hopefully I'll be fine.
jason
N4VR
RV-7 (Flying)
Old 01-04-2012, 11:17 PM
Yeah, their instructions for just about everything I've procured from them could definitely use some improvement. The *products* are very nice, stylish, well designed, etc. It's their documentation (or rather, lack of it) that could use a little help.
Santa Clarita, CA
#8,000
Old 01-05-2012, 12:29 AM
craigvince's Avatar
As a general rule, we always use shielded wire for anything lighting related. It's something I learned to do a while back, but I'm not sure why. Probably from the old days when the zing-zing strobes had to have shielded wire to keep the noise down.
I wouldn't worry about going back and rewiring with shielded. Chances are you'll never have an issue with it. The newer generation of LEDs (we install both Aveo and AeroLEDs) are very quiet.
