Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 01-08-2012, 12:23 AM
comfortcat's Avatar
comfortcat comfortcat is offline
Talking Not all checklists, all checklists...
I meant that all manufacturers have a check brakes step in a checklist BTW: My IFR instructor did include a "check brakes" before landing; the "Undercarriage" part of GUMPS on a fixed gear.
All check lists? Can you imagine:
ENGINE OUT CHECKLIST
Fuel to both (Cessna thing)
Primer Locked
Ignition both
Brakes Checked
Mixture rich
Originally Posted by krw5927 View Post
Startup checklist, yes. But I don't have "Check Brakes" on my PRE-LANDING checklist, as there's nothing for me to do if I check them and they go to the floor. I still have to land and I certainly can't service them from up there.
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 01-10-2012, 10:13 AM
Michael White's Avatar
<snip> I don't have "Check Brakes" on my PRE-LANDING checklist, as there's nothing for me to do if I check them and they go to the floor. I still have to land and I certainly can't service them from up there.
Perhaps nothing you could do about it, but it would give you a heads up for what to expect after touch down...before you get there.
Moose
VAF #136
Old 01-11-2012, 12:07 PM
flyboy1963's Avatar
Default locked or inop brakes = ......????
So you hi-timers out there, or any unfortunate enough to have experienced this....if brakes are unknown, or possibly one is locked, are you better to land on grass?.....slippage = less force on gear, nose over, etc.
other options...
- would the fire guys foam the runway to make it slippery? ( like I've heard done for gear-up landings)
- if you're Bob Hoover, touch each wheel lightly to see if it's locked.
- if not, then land,
- if locked, go find a frozen lake?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 07-17-2014, 08:42 PM
drjjbrown drjjbrown is offline
Default Parking brake mounting bracket
Bruce
Beautiful install on the new Matco parking brake valve. Where did you get the bracket. It looks like the one from Van's is for an old style Matco valve. Not to mention he wants $179!! for it.
Jeff
Old 07-17-2014, 09:34 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Originally Posted by drjjbrown View Post
Bruce
Jeff
Order an F704k upright cap strip and cut it down. This will give you a nice parking brake standoff like Bruce's. It also provides a means to develop a stopper device and rivet it to the side of the standoff bracket.
I copied Bruce's design and am very pleased. So far I used it for transport of my aircraft to the airport and on various engine runups. It's a very positive lock and does not bleed off. You won't take off with it on!
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 07-20-2014, 02:58 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Hi Bruce,
I like that cable from ACS ... What length did you use ?
Best regards
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 07-20-2014, 06:59 PM
bruceh's Avatar
bruceh bruceh is offline
I think I only needed a couple of feet, so buy the shortest length. This particular control is one you can cut to fit.
Bruce Hill
2020 VAF donator
Old 07-20-2014, 10:53 PM
airtractor8 airtractor8 is offline
other options...
Yes, I had the brakes lock solid one night on landing after a night spraying sortie in an early 502 Airtractor. The early models had the park brake on/off valve on the lower subpanel that worked the same as the Matco type we have in our RV's today. It had a simple 3"long "throw over" lever on the valve to operate it.
During flight the field map and job details had fallen to the floor and I had reached down to pick them up and un be known to me(dark cockpit) the leg of my flight suit had bumped the park brake valve to the ON position
All was good until I needed some brake to keep straight on the landing roll. As you can imagine this resulted in one brake locking and was quickly followed by the other as I tried to keep the thing straight and on the runway. Fortunately I was in the latter part of the landing roll by then and on a gravel strip with the tailwheel down and locked. The result was a less than elegant sideways grinding halt in a cloud of dust but no harm done to the aircraft.
Airtractor changed the park brake mechanism after that
The message here is make sure you fit a LOCKING actuator cable to your park brake so this can't happen to you!
Old 07-21-2014, 07:23 AM
JanRV6UK's Avatar
Thanks Bruce !
Jan
Old 07-21-2014, 09:08 AM
WenEng WenEng is offline
Default Mine is 5 feet.
Jan, I bought the 8 ft one. It was less costly than the shorter lengths ( probably because they would have to special cut shorter lengths). I panel mounted it and routed it up and over to just left of the firewall recess , then down to the parking brake (mounted next to the recess). That was just under 5 ft. When you pull the cable out to trim the sheath, take care not to lose the little ball bearing residing inside the sheath. It slips back in easily.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
