  #11
Old 01-05-2012, 09:19 AM
Strasnuts Strasnuts is offline
Default Airtex
I used AirTex and it does have the backing. I believe it works great for noise dampening too. There are a lot of areas especially around corners or bends where you have to shave the foam backing off. No big deal...just more labor on the install.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 01-05-2012, 09:26 AM
aerhed aerhed is offline
Use a small wire wheel (1-2 inch) in a drill or dremel to mill the foam back from edges before binding. Easier to sew, less lump.
Actual repeat offender.
Old 01-30-2012, 08:57 AM
vjwodack vjwodack is offline
I took over a botched restore job and found the interior the used was not flame resistant. I treated all the interior surfaces with flame stop and all of them were tested and approved by the DAR we had inspecting the project. If you choose to go to a local carpet store for carpet, flame stop should be a good alternative if they don't have something flame retardant already in stock.
Old 01-30-2012, 11:37 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Originally Posted by Kyle Boatright View Post
Purchase carpet that meets "Class 1" fire rating standards. Many products fit that description - they are commonly used in hotels, hospitals, schools, etc. Generally, the carpet will be a commercial grade product with a loop pile.
Boiled down to the basics, if you set one of those products on fire, the flame will self-extinguish after burning a very small area. Most of those products use Nylon 6 or Nylon 6.6. as the face fiber. Wool face fiber does exceedingly well in fire tests, but far fewer carpets are wool these days.
Be aware that a Class 1 fire rating does not mean that the product meets FAA standards.
I would assume that any automotive carpet that meets current standards for cars would also meet the requirements you state above.
Is that correct?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-30-2012, 04:16 PM
Is that correct?
Wish I could help, but...
I don't have any knowledge regarding automotive carpet - my employer hasn't been in that market in about 20 years, and I was never involved in that segment.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-24-2014, 02:46 PM
bcondrey bcondrey is offline
I remembered reading that Abby (Flightline Interiors) no longer does carpet - that is not correct. I just got off the phone with her and she does indeed still do carpet. It's available as part of her entire interior kit or alone as just a carpet kit. As I recall it comes with "heel protectors" attached below the rudder pedals and floor mats to go on top of the carpet for the rear seats.
Bob
Old 03-24-2014, 03:31 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Aerosport Products will be offering a full carpet kit for the RV-10. We will start taking orders April 15th. You can call us and discuss at any time. We are finishing up burn testing and colors at this time. We will offer the carpet with a serged edge or a binding edge. See photos. These will cover entire
interior.
Serge edge and bind edge (lower)
http://www.aerosportproducts.com/
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 03-24-2014, 03:59 PM
Tim 8-A's Avatar
Tim 8-A Tim 8-A is offline
Just when I thought I was done spending money with AeroSport Products
Tim Blake
Colleyville, Tx
RV8a Purchased flying (many changes) Sold
RV-10 Purchased flying.. Panel upgrade complete.
G3X/Dynon/TT
All new interior complete.
Flyin like a dream.
Old 03-24-2014, 04:01 PM
flyboy1963's Avatar
Default ...I keep thinking 'fire'....?
okay, call me paranoid. Anyone can correct me if I'm wrong, but I'll bet the reason the foam-backed carpet isn't fire rated...is...well, because it BURNS!
Yes, the foam is a great sound deadener I suppose, but think twice about slathering your interior in this toxic smoking stuff!
There are quite a few hi-temp acoustic mats available for hi performance sports cars etc. that will not fill your cabin with thick smoke in the first 30 seconds of a fire. ( Summit Racing etc.)
Where I added some of the common 'aviation' foam under the floor carpet, I sandwiched in double thick aluminum foil, taped all seams, and set on top of a fibreglass matt. All carpets & upholstery were soaked numerous times with Flame-Out solution.
My unscientific burn tests showed a much improved time before any smoke was evident. Lots of previous threads with Dan Hortons's awesome testing results.
Just hate to see anyone go fast, cheap, and easy, and regret it later!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-24-2014, 05:17 PM
RVDan RVDan is offline
In the past some of the flame retardant treatments have been found to be corrosive to the extent of causing airframe damage where the treated materials contact metal. Is there any information on the Flameout treatment that indicates that the residue is not corrosive? Just wondering.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
