I hung my engine this weekend on my RV-9 - but I think it needs to come
off again. Vans supplies 2 large diameter AN7 washers in the
engine mount bolt kit that are to shim the forward faces of the
lower engine mounts off the engine so that the mount clears a
"step" in the engine casing. The "step" is the mounting flange
for the oil sump.
All's well on the right lower mount, but on the lower left its
as if the shim isn't thick enough, or more to the point, the
flange on the engine protrudes too much. Consequence is that
mount doesn't sit flush on the engine - its slightly at an
angle with the top part of the mount making contact and the
lower part interfering with the oil sump flange.
Is this a common problem or am I breaking new ground here
I
guess the obvious solution is to pull the engine and grind off
the flange on the oil sump mount. I'm more than a little
hesitant about doing surgery on my engine.
