I never tried the EIS Log program but did use the Waiters Flight Data recorder program. Once I hooked up the serial data line to my computer and got the right serial port selected in the software evrything worked great. Don't forget to keep the laptop powered up and don't let it go into hibernation.
I have a little schematic of the data cable I made up if you want it. Also, a lot of laptops come with USB but no serial port. I bought a serial to usb converter and used it successfully, again after setting up the right serial port number in the software.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
