Old 01-01-2012, 06:35 PM
twcroy twcroy is offline
Default Slight Rotation of Brake Assemblies
Folks,
My A&P and I replaced a set of brake pads yesterday and he noticed the brake assembly on each wheel rotates slightly (I'd guess 1/16" each direction). Is this normal / ok? His concern is it will eventually wear through the bolt or elongate the hole necessitating a new axle. Also concerned if a brake malfunctions steering is lost.
Happy New Year and appreciate any guidance.
Tim
Old 01-01-2012, 07:13 PM
Greg Arehart's Avatar
Not sure if it's normal, but you're unlikely to require a new axle. More likely, a new brake bracket. Probably not a safety issue (if I understand correctly what you are describing) at this point, but worth replacing the bracket at the next opportunity.
greg
Greg Arehart
N 7965A
Old 01-01-2012, 07:37 PM
Walt's Avatar
Walt Walt is online now
Originally Posted by twcroy View Post
Folks,
Tim, I'm not sure I understand exactly what you are talking about, but there should be no slop in the assembly except where the caliper anchor pins go through the anti-rotation bracket (normal for the caliper to free float a bit).
The Anti-rotation bracket is bolted to the axel and there should be no slop in that hole. If that bolt is loose in the hole than you need to be looking to step it up to an oversize hole for a nice tight fit or perhaps replace the bracket like Greg mentioned above.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-02-2012, 09:31 AM
Thanks Greg and Walt,
Is the bracket you're referring to the sleeve that goes around the axel with the bolt going through it or another component?
Tim
Old 01-02-2012, 09:53 AM
Walt's Avatar
Tim
Yes, the one that the caliper pins go into.
Old 01-02-2012, 12:24 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
In my experience, it's the Brake Flange (WD-4??) mounting holes that are becoming slightly elongated. You will see this on almost all mid-time RV's. It can be replaced with a new one and mounting bolts during your next brake pad/tire changeout.
Probably not a huge safety issue (unless you are seeing abnormal bolt wear), but it will result in a small amount of play in the brake assy and wheel fairing...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 01-02-2012, 12:35 PM
Default Brake Assembly Rotations
Thanks Walt and Joe. My A&P says it's definitely the axel / sleeve bolt and hole with the play. I'll call Vans tomorrow to see what size bolt we can go up to and put it up on stands to get a better look.
Tim
Old 01-02-2012, 01:13 PM
jsharkey's Avatar
jsharkey jsharkey is offline
I noticed slight play - just enough to feel - at my second annual and around 70 hours. I'll see how it progresses at the next inspection. Thing is in an RV - unlike a car - you only brake going forwards so there is no reverse load cycling on the holes to open them up faster.
Sounds like a design mod to include a thicker walled axle sleeve is needed.
Jim Sharkey
RV-6
Old 01-02-2012, 04:18 PM
Toobuilder's Avatar
This attachment method is very common on this type of landing gear leg/axle. Because of the high torque loads and thermal cycles, it is really tough to keep the bolt from working the hole. This is one of those situations that requires a reamed (perfectly round) hole, and an interference fit fastener. If you can put the bolt in place without a hammer and drift, it's too loose.
You might be able to save it by reaming slightly oversize and going with a specialty fastener.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-02-2012, 04:36 PM
Larco's Avatar
Larco Larco is offline
Tighten the bolt
