Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 12-31-2011, 05:08 PM
Walt's Avatar
Walt Walt is offline
Default RV-8 Prop Balance Results
Just thought you'all may be interested in today's prop balance. John brought this over for a vib check today as he has noticed a "slight" vibration, turns out it was more than 2X the upper limit! We improved it from 0.414 IPS down to an amazing low 0.016 IPS
Needless to say John is very happy.
Plot of balance Run: 1) 0.414, Run 2) 0.170, Run 3) 0.016
Spectrum Analysis: Good looking engine inside and running smooth.
Happy New year!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-31-2011, 05:25 PM
Geico266's Avatar
Geico266 Geico266 is offline
Nice work Walt.
It was a pleasure meeting you n the RV -1 project. Thanks for taking the lead with the avionics and wiring. You da man!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-31-2011, 05:32 PM
SmilingJack's Avatar
Default Mirror vibration question...
Walt, again, nice work and I have a question for you.
My guy was able to get my vibes down to .008, yes I feel lucky and do feel the difference by completing aprons balance,
So, here is my question: on my RV-8 I have 2 mirrors mounted on the roll bar. Why is the right hand mirror rock solid clear with zero vibration noticed while the left hand mirror is not clear and vibrates?
Is it because of the prop rotation?
Any suggestions on reducing the vibrations in it?
John Mastro
RV-8
Old 12-31-2011, 05:38 PM
Walt's Avatar
Same here Larry, great meeting you.
I really enjoy doing avionics work, it's always been good therapy for me. My RV1 design philosphy is "how simple can I make this thing" so from that perspective it's a bit of a challenge.
I think I have it down to 1 relay, 2 switches and about a dozen wires, pretty good for a airplane with a starter, alternator, transponder and com radio. I'm really keeping this one "light and simple", just like our founding father would have liked it
Old 12-31-2011, 05:40 PM
Geico266's Avatar
Can't wait to see it. Simple is good because I understand it!
Old 12-31-2011, 05:46 PM
Walt's Avatar
As far as the Mirror I really have no idea why one would be so much different than the other unless the mount is not exactly the same. The 8 rollbar is so small and the distance between the 2 mirrors is quite minimal so it does seem strange they would be different.
PS: I'd be curious to know what machine he is using just for reference.
Old 12-31-2011, 05:55 PM
odens_14 odens_14 is offline
does anyone know someone who does this in the "RV range" of vermillion, SD. I think I have a fair amount of vibration in my rv and would love to smooth it out.
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 12-31-2011, 07:55 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Smooooooooth
Just a note to say thanks to Walt for excellent work and a pleasant visit too. Walt did the leak test on my static system and a W&B a month or so ago, and so I wanted to use him for the balancing act too. My 8 always vibrated a little especially when throttling up to about 2000 rpm to cycle the prop. That vibration went away after Walt added the first trial weight.
The smoothness was very noticable even on runup and the engine felt wonderful climbing out from 52f to go back to Hicks. 5 minutes into the flight home I was smiling and enjoying the new sense of confidence that having a smoother running engine brings. Of all I've spent on this plane, this was the best bang for the buck.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 01-01-2012, 05:45 AM
pierre smith's Avatar
Default Resonance.
We balanced my 110" prop on the Air Tractor to almost no numbers and it is really, really smooth.
Nevertheless, the engine has very high pitched resonance and even the trim tab pushrod bushings wear yearly.....amazing. The compressor section typically operates at 92-95% of 37,500 RPM..no typo! Double checked.
On the -10, we balanced it carefully and you'll be amazed at how little maintenance a balancing job provides. Exhaust pipes and welds not cracking, alternator mounts not loosening or cracking, etc....the benefits to balancing are too many too name.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-01-2012, 03:48 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Balancer might not be as fancy as Walts, but we got this result on the -10 and she felt like a turbine.
http://s849.photobucket.com/albums/a...filter=noflash
This tells you one thing...... You need more decimal places!
