Old 12-31-2011, 01:46 PM
C-GRVT C-GRVT is offline
Default oil hose restrictor fitting to engine mount clearance
This is a question that I have never seen asked, which suggests it is not a problem. But it seems to me that it might be.
The VA-128 restrictor fitting that screws into the engine oil pressure port (the 45 degree fitting that has to be installed prior to fitting the engine to the mount) and that attaches the engine end of the oil hose going to the firewall mounted transducer manifold seems to run very close (3/16" clearance) to the right rear motor mount.
Is that a problem? I am of course concerned that engine movement might cause the fitting to contact the mount. Even though it is right at the mount, and so movement would not be as great as farther away, it seems awfully close.
There is a second engine port at 90 degrees to the one used (Aerosport installed the fitting) that faces directly rearward that would not have that clearance issue. Is that a port that can be used instead if the other one is a problem? I would have to remove the engine from the mount to change fittings.
Bill Brooks
Ottawa, Canada
RV-6A finishing
Old 12-31-2011, 03:34 PM
frankh's Avatar
frankh frankh is offline
Default I hate those things!
You can use either port on the engine.
But the real point is why use a 45 degree fiting?..God forbid you get a leak cus good luck trying to get a wrench on that fitting.
A much better idea I think is to use a straight fitting on the port that points straight backwards..Then its a simple case of using a deep socket to install or remove the fitting.
Ok I know its a restrictor, I don't think that it necessarily has to be a restrictor if you have a damped EFIS..But that is easy to fix too, just buy a regular fitting, braze it full and drill a hole in the plug.
Oh and plenty of clearance.
Frank
Old 12-31-2011, 08:33 PM
johnfurey johnfurey is offline
I had the same questions after I mounted it there as the plans called for. Everyone I called said it would be fine but I just wasn't comfortable with it. I dropped the engine and moved it the the rear port.
John Furey, RV7. Ohio
Life's Short...Fly Often!
Old 01-01-2012, 08:02 AM
John,
I think I will do what you did and move the line to the other port. It surprises me that this is not seen as a problem, the fitting really is very close to the mount. There must be many aircraft flying like that, but the consequences of a fracture of the fitting would not be good.
Bill Brooks
Ottawa, Canada
RV-6A finishing
O-360 about to come off
Old 01-01-2012, 08:37 AM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
Default Picture please.
Is there any chance of somebody posting a picture please just to see and get an idea of the issue. I seem to remember Dan Checkoway had this issue but as his RV-7 site is no longer available, I cannot verify.
Thanks in advance.
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
Old 01-01-2012, 10:52 AM
Default photos
http://i1208.photobucket.com/albums/...1/IMG_3067.jpg
http://i1208.photobucket.com/albums/...1/IMG_3070.jpg
http://i1208.photobucket.com/albums/...1/IMG_3069.jpg
Anthony,
here is a link to photos - I find photos can be misleading because of perspective, but it should give you the idea. The fitting can be rotated slightly, resulting in increased or reduced clearance to either the metal engine mount cup or the rubber of the mount, but not to a place that provides what seems to me satisfactory clearance from both.
There is a note on the Van's drawing of the oil system (OP something) pointing out that some engines have a second oil port at the rear, and it may be better to use that. There is no explanation of why Van's suggests that may be "better", could just be because it is more accessible and you don't have to pull the engine to change the fitting.
Standard practice seems to be to use the less accessible port (my engine came set up that way).
BY the way, the hose is just test fitted, so no firesleeve yet.
Bill Brooks
Ottawa, Canada
RV-6A finishing
Old 01-01-2012, 11:56 AM
Thanks Bill for the pictures. Can you use the port I have outlined in the photo or is this the one to avoid?
Anthony,
Bill Brooks
Ottawa, Canada
RV-6A finishing
Anthony Johnston
Anthony's RV-4
Old 01-01-2012, 01:42 PM
jrs14855 jrs14855 is offline
Default port
Unless you have a relatively new accessory case you will probably not have an aft facing port. The Pitts S1S and S1T(and perhaps other model Pitts) were certified with a 90 degree brass automotive fitting in the port that faces to the side. A standard straight AN fitting is then installed in the brass elbow. The automotive fitting is shorter than the equivalent AN fitting, but more important it is much easier to get a wrench on the automotive fitting.
There is a recent post that says not to use brass fittings. This is hogwash. 40's and 50's Pipers used brass fittings almost exclusively.
My understanding of the restrictor is that the purpose is to minimize oil loss in the event of a failure downstream of the restrictor. Even with a #60 drill restrictor there will still be a lot of oil loss in the event of a failure but at least the restrictor will buy some time.
Old 01-01-2012, 02:07 PM
frankh's Avatar
Default Hmm
Better use a restrictor on the oil cooler lines as well then eh?....NO DON'T DO THAT!..
Your photo showing the rear facing port makes the argument for a simple straight fitting..You can simply install with a deep socket..MUCH easier.
Steel fittings are available from your local hydraulics emporium which may be turned into a restrictor fitting if you feel its necessary.
Frank
Old 01-01-2012, 02:33 PM
Default Thanks Frank and Jim.
Thanks Frank and Jim, your posts have made this issue much clearer to me anyway. I have heard about the corrosion of brass fittings mounted in steel casings, so I will probably go with steel fittings.
Anthony Johnston
Anthony's RV-4
