Old 12-30-2011, 03:00 PM
jcaplins's Avatar
jcaplins jcaplins is offline
Default drill press
I'm looking to get a drill press soon and wish to hear anyones opinions or reviews on a couple in my price range.
I want a drill press with a wide range of speeds; ~250 --> ~3000 rpm. For this I find my search leads mostly to 16 speed floor models.
such as:
the harbor freight central machinery model 43378 ($279.99):
http://www.harborfreight.com/merchan...ess-43378.html
And what looks like the same with different paint from Northern tools ($279.99):
http://www.northerntool.com/shop/too...5430_200365430
Northern tools also has what appears to be the same thing in a bench top model plus a laser ($289.99):
http://www.northerntool.com/shop/too...5429_200365429
Anyone have any reviews for these three models or something I should consider instead?
Pros and cons of floor vs bench top? (I do little to no woodworking, only RV stuff)
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 12-30-2011, 03:17 PM
DaAV8R DaAV8R is offline
Default Drill Press
Get the biggest one that fits the budget. I recommend adding a cross feed vice to the drill press. It makes the drill much more functional and provides a method of fine adjustment to your drilling.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 12-30-2011, 03:33 PM
Mel's Avatar
Mel Mel is offline
I've been using the HF floor model, 16 spd. for about 19 years. And I use it a LOT! No problems except you'll want to throw away the "peanut-butter" bolts that come with it and assembly it with real hardware. Lowest speed on mine is 170 rpm.
I was going to bite the bullet and buy a good Craftsman drill press until investigation showed that it was the same drill press painted a different color and marked up about 100%.
A floor model takes up floor space whereas a bench-top model takes up work bench space. I personally prefer the floor model.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-30-2011, 03:55 PM
jrs14855 jrs14855 is offline
Default drill press
I've been using the Harbor Freight floor model for about three years now. By all means buy the floor model. The motors do draw a lot of current on start up but once up to speed everything is fine. I just did some 3 1/8 instrument holes on the lowest speed setting with a circle saw. Much better results than my previous drill press which did not have the low speed capability.
Old 12-30-2011, 04:13 PM
jcaplins's Avatar
sounds promising so far.... Any trouble with wobbling chucks or anything else?
Jeff Caplins
California
RV7 N76CX
Old 12-30-2011, 05:41 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Before you buy a drill press, you might read and consider this thread in the tools section :
http://www.vansairforce.com/communit...ad.php?t=51159
Short story: I needed a drill press but bought a bench top mill instead. Does everything a drill press can do, with better speed control, and does a lot of additional things that no drill press can do.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 12-30-2011, 06:19 PM
jcaplins's Avatar
Brad,
I had already read that thread, looked into it, and I would absolutely love to get a mill instead. Unfortunately I can't see spending the money. It would be 2 to 3 times the cost, plus all the accessories needed.
Jeff Caplins
California
RV7 N76CX
Old 12-30-2011, 07:26 PM
John Courte John Courte is offline
Many moons ago when I started this project, I got a floor-standing radial arm drill press from Harbor Freight. On paper it looked like the greatest thing since sliced bread. In practice, it's not all that wonderful. Locking the adjustment knobs makes the bit drift by as much as 1/16", which is annnoyance, but workable. There's also some wobble in the main chuck bearing.
If I had to do it over again, I'd get a smaller, but better-built and more precise machine instead.
RV-7 N313TD
SOLD 7/2/2020
Old 12-30-2011, 07:43 PM
TX7A TX7A is offline
I got the 16 speed HF that you're looking at. I haven't had any problems. What I really like is that I can put it on the slowest speed and make some really nice lightening holes using a fly cutter. (clamp the part, slow feed & some squirts of kerosene)
Good luck!
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 12-30-2011, 08:27 PM
Lars Lars is offline
Have a look at Ebay, too. I've found some great deals on old US made power tools. If you are patient you can get a lot more for your money, and nearly all the old US-made stuff is indefinitely rebuildable.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
