I just finished drilling the wing conduit holes in the left ribs. As with everyone else I went with the 1 X 3/4 inch hole plus I drilled out the tooling holes on either side of the pitot hole to 3/8 of an inch.
Is it necessary to do the same thing to the right ribs? I only plan on running an Aveomaxx 6-in-1 wing tip landing light on the right side. Should I be considering anything else for the right side?
