Old 12-27-2011, 07:42 PM
N64GH's Avatar
N64GH N64GH is offline
Default "CROW" safety belts
I got a real cool set of CROW safety belts for Christmas. I was installing them today and ran into a slight problem. The anchor points have a hole of about 7/16 the old belts I am removing (RV6) the hole is sized for a AN4 (1/4) bolt :roll eyes:. I was working on making some bushings today. What I did will work but ... not really happy with what I maid. Any one else install the CROW belts and what did you do?? Not a huge deal but I was kind of hankering to take those puppies up for a flight
Mike Divan
Mike Divan
N64GH - RV6,flying
Once an Airman always an Airman (SSgt 78-82)
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
Old 12-27-2011, 08:09 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Check the archives by searching. Your not the only one who has dealt with thisw. Either you can find bushings that fit or, as I did, just drill a new 1/4" hole higher up on the tangs. You have plenty of room to do so.
Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
N64GH's Avatar
Default Never Mind
I found a thread that has some suggestions I will try tomorrow.
Mike Divan
N64GH - RV6,flying
Old 12-27-2011, 08:25 PM
douglassmt douglassmt is offline
Default Metric washers
I recently went thru this, one thread said metric washers stacked would work perfectly, and it did. 6mm if I recall. Still haven't gotten the answers for connecting the crow tabs to the ceiling bolts in the RV-10, but those tolerances are much closer, might just go without any bushings. Ace hardware has metric washers.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 12-28-2011, 06:46 AM
330drvr 330drvr is offline
6mm washers work great!
