Old 12-27-2011, 12:53 PM
RV8R999 RV8R999 is offline
Default iPad-1 3G IOS 5 issues
anybody else having issues with Safari and/or Foreflight crashing since upgrading to the lastest IOS 5.x version?
Ever since the upgrade Safari is very slow both in WiFi and 3G often crashing several times before being usable.
ForeFlight did this during a flight yesterday as well.
It isn't a heating issue.
Thoughts?
Old 12-27-2011, 01:29 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by RV8R999 View Post
anybody else having issues with Safari and/or Foreflight crashing since upgrading to the lastest IOS 5.x version?...
I haven't used Forflight much but Safari has crashed more often for me since the latest upgrade. Not as bad as yours though.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 12-27-2011, 02:43 PM
Brantel's Avatar
Brantel Brantel is offline
No problems here...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-27-2011, 03:23 PM
Thoughts?
Crashes once in a while but recovery is super quick.
Old 12-27-2011, 03:32 PM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
Default Mine is ok.
Mine works fine, maybe you should try doing a restore in iTunes. You won't lose your stuff if you sync it first.
Randy Walls
Cessna 120
Old 12-28-2011, 07:17 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default iPad crash
I haven't had any problems since they came out with the update to fix it. Keep it synced every couple of weeks and it should work fine.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
