Old 12-26-2011, 11:06 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Control cable torque?
According to my chart, the proper torque value for the nuts that secure the mixture/throttle/prop control cables should be torqued in the 500 in-lb range. That value is understandable for a solid bolt/nut, but for a hollow tube? This seems high. I am curious if there is a different torque method for these nuts, or if this is correct. I am concerned about damaging the cables torquing to this value.
I was unable to find anything with a search, so I tend to think I'm missing something obvious. Any hints?
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 12-27-2011, 07:26 AM
Walt's Avatar
Walt Walt is offline
I'm sure there is a torque value somewhere (Gil will find it) but I've never seen one. I'm sure that if you torque it to 500 in lbs it will snap long before that
Treat it more like an AN tube fitting and you should be ok, to me it's one of those "goodntight" torques
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-27-2011, 08:24 PM
vmirv8bldr's Avatar
Default Checked with A&P
I stopped in a checked with the A&P at the airport today. He said these nuts are kept tight by the internal tooth lockwasher, and all we're shooting for is to get the lock washer to bite a bit, but not crush the teeth of the washer. So, as a rule of thumb, get it snug, and then a quarter to half turn and you're done.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
