Go Back   VAF Forums > Model Specific > RV-6/6A
Old 12-26-2011, 10:43 PM
Dakbuster Dakbuster is offline
Talking First flight ZK-BRV
Just to let all know another RV6 Kit number 250-55 has successfully taken to the air for a short 15 minute flight (almost a 17 year build)
Aircraft performed flawlessly
My thanks to all those who don?t know they helped on this forum
Regards
Bruce Black
New Zealand
RV6 finished and flying.
Old 12-26-2011, 11:41 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!!!!!!!!!!!
Bruce, good for you.!!!!!!!!!
Now, where are the photos?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-26-2011, 11:58 PM
Thanks Mike
still working out how to put the photos on here
Bruce Black
New Zealand
Old 12-27-2011, 12:20 AM
My first attemp at posting pictures hope this works
http://i42.tinypic.com/205f4eh.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Bruce Black
New Zealand
Old 12-27-2011, 01:57 AM
planejames's Avatar
planejames planejames is offline
Default Congratulations
Well done Bruce, good to see another RV in the skies above Tauranga.
James Pengelly
NEW ZEALAND
RV-7 Wings
Old 12-27-2011, 02:02 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Image Post
Did it for you.
Simply click on the small postcard icon in the toolbar, paste your url in the box that pops up and voilà!
Bt the way, very nice plane. Congrats!
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 12-27-2011, 02:22 AM
Default Cut off the underside of the external canopy latch handle
I can see part of the reason for the 17 year build - the firewall forward is impressive. I would like to know the top speed at 6000 ft d.alt. when you have that nailed down.
From what I can see the craftsmanship is outstanding.
One thing - in the photo the external canopy latch handle rear end is pointed forward as they will do from time to time. If one of those times you slide the canopy forward the unmodified handle will strike the fiberglass extension from the windscreen that overlaps the slider when closed. If you trim off the aft lower surface of the handle at an angle it will clear the fiberglass with no contact otherwise it will hit and cause minor but heartbreaking damage to the fiberglass.
Bob Axsom
Old 12-30-2011, 09:19 AM
gongreg gongreg is offline
Now that's a beautiful plane! Congrats!
Old 12-30-2011, 05:56 PM
Thanks to all for the compliments. They are appreciated.
Bob: re the canopy handle both have already happened (don?t know when) but I now have the repair on the fibreglass on top of the windscreen and the modified latch. /Speed I am hoping to get 155knots on 50% power with 23litres/hour any better than that will be a bonus (If it?s worse then will have to look for some extra airframe cleanup) Craig Catto says I should get VNE @ 75% power so when I get it sorted will let you know. I must also one again thank you for the help you gave me a couple of years ago when I was trying to get my wings sorted and attached at the correct place. She flies hands off level and straight.
My first flight I climbed at full power and 75 Knots to circuit height (which I reached very quickly after about a 550foot ground roll),I reduced power to 1600rpm and turned down wind. I found I had reached 145knots and still increasing so I reduced power to idle. I continued down on the downwind leg at 145 knots trying to wash off the speed. I turned onto base leg still doing 100 Knots. It was not until I was well established on final that I managed to get some flap selected. All I can say is this is one slippery little sucker. (My first RV landing i think it handles much like a PA18 close to and on the ground)
Now I am waiting for our weather to clear we are in the middle of a rain depression (the remains of a tropical cyclone) we have just had two days of heavy rain with another two days to go then we should be in clear weather again so the real testing will start.
regards
Bruce Black
New Zealand
