Go Back   VAF Forums > The Never Ending Debate Section > Tools
  #21
Old 01-18-2019, 10:03 AM
Also add a #19 reamer for those #8 screw holes.
Dave
RV-3B, building the fuselage
Old 01-18-2019, 08:18 PM
Tommy123 Tommy123 is offline
The reason to use close tolerance bolts is just that, the pecs are going to be tighter. Don't assume a 5/16 AN bolt is going to be exactly 5/16. I would mic the bolt and see what size it is exactly then ream accordanly.
Old 01-18-2019, 09:53 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Don't over think it
I have a few reamers.
I don't recall a single time that I used a reamer on my slow build 7A.
It has been 10 years though.
Do the plans mention a reamer anywhere?
OK, I'll answer my own question. I have the plans on CD and just did a search for the word "reamer".
It shows up 5 times. Only twice in the the actual details of the plans. Both times are when building a tip-up canopy.
And one of those times it goes on to say a drill would be ok if you don't have a reamer :-)
I built a slider :-)
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
