Conduit is not required; it just makes things easier if you need to run more wire(s) in the future. 7/16 will probably not be large enough for pitot, landing, strobe and nav lights. If you add a roll servo in the wing you will also need an even larger grommet from the bell-crank inboard..
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
