Old 12-22-2011, 03:37 PM
AaronG AaronG is offline
Default Troubleshooting alternator noise
I'm looking for some advanced ideas on troubleshooting alternator noise. I searched the achieves and have not found anything that works. Here are my details:
RV10 with IFR panel
Plane power 60A main alternator
High pitch noise that stays at constant pitch but gets louder with load
Existed since day one with new PP alternator
Noise is eliminated when main alternator is turned off
Noise is eliminated when ps8000b intercom is turned off
Noise is eliminated with b&c backup alternator and zeftronics regulator
Both alternators go to same main bus copper bar
All jacks have isolation washers
Adding the lonestar alternator filter at the PP alternator did nothing
Any ideas for next steps. Right now i'm thinking of returning the PP alternator, or adding an inline filter to the intercom. Any ideas for a light and inexpensive filter? The ones for sale look both heavy and run $100 plus. Given that the alternator filter did nothing, I'm hesitant to spend more on filters.
Old 12-22-2011, 03:57 PM
Walt's Avatar
Walt Walt is offline
If the alternator is "good" the noise is caused by high a resistance in the circuit somewhere, either the power or ground circuit to the alternator. I would start by checking all the cables and terminals starting at the alternator and going all the way back to the battery, also verify the alternator is properly grounded to the engine case. A bad crimp or bad connection somewhere is likely the problem. It could be a bad regulator in the alternator but I would check all the connections before condeming it.
Adding more filters is not the answer so don't waste your $$
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-22-2011, 04:02 PM
rocketbob's Avatar
Alternator noise is almost certainly caused by a bad diode in the alternator which causes a ripple AC voltage to appear on the bus. Easy way to check for this is to put a voltmeter on your bus turned on to AC and note if there is an AC voltage present when the alternator is on. If there is, replace it. A better instrument to use would be an oscilloscope if you have access to one.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-22-2011, 04:15 PM
jthocker's Avatar
jthocker jthocker is offline
Ooh an oscilloscope, I think I have room for one of those in my panel!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 12-22-2011, 04:31 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Do you happen to have a 296,396,or 496 in there with ship's power and audio coming out of the jack and into the panel? The hardware in those units isn't isolated properly, and it is a common source of alternator whine getting into the audio system. They seemed t have done better on the 696. Just another thing to check.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-22-2011, 04:48 PM
Walt's Avatar
Bob, you are correct, however, a bad regulator will cause increased alternator noise intensity (get louder) with increased load but is not affected by RPM. A bad diode will cause a change in pitch with RPM changes and is generally not affected by load.
Hence my deduction that this alternator may suffer from a bad regulator, but I would still check all the connections and grounds first.
Old 12-22-2011, 05:27 PM
rocketbob's Avatar
You do not!
N8155F C150 flying
Old 12-22-2011, 05:41 PM
Walt's Avatar
Nano O scope for your panel, I think I am going to add one of these to my own panel now, good conversation piece!
