Old 12-21-2011, 10:11 AM
Phlyan Pan Phlyan Pan is offline
Default Group Building?
I'm aware of the two RV-12s being (already?) built by high school groups. I'm curious if anyone has ever attempted building as a group of owners, as in a club situation?
I guess I'm just looking for thoughts as to whether or not such a venture would be possible and maybe some thoughts on how to structure it to ensure a smooth and more importantly safe build with so many hands on at one time.
Old 12-21-2011, 11:14 AM
n981ms's Avatar
n981ms n981ms is offline
A subgroup of 7 out of our EAA chapter are currently building a Zenith 750. So far so good. We set out to build a simple day vfr airplane and have not deviated far from that. We Started in Spring 2011 and have the tail group done and wings are nearing completion. I think the key to success will be a plan from the out set and a simple one at that. The more complicated the airplane the more decisions there are to make. More decisions means more different opinions. You know what opinions are like. While we have not yet proven that it can be done we are on our way. I think. Good luck.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 12-21-2011, 11:25 AM
videobobk's Avatar
videobobk videobobk is offline
I am pretty heavily involved in the HS build in Indiana, so may have some insight on this. I can't see any problems, other than you will have to have more tools and perhaps a little more space than an individual or partnership build. The extra space comes in when you realize that for you will pair off and work on more components at a time. I do have a tool list that has worked for our group that I could pass on, but ours is probably a bigger group than you are talking about. Anyway, let me know if you want it.
There really doesn't seem to be much problem working as a group. You will have to structure yourselves so that things are recorded properly, and inspection becomes a cross-check among the workers. I think it is a great idea. BTW, what other HS build are you referring to? I assume you mean Teen Flight II (which I don't think is in a high school) but would like to know if it is another build.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 12-21-2011, 11:26 AM
pierre smith's Avatar
Default Rudi Greyling
In South Africa, Rudi Greyling spearheaded an effort by ten men, to build their RV-12. It has since flown and I believe at least one of them soloed it and is on the way to getting his license.
The entire build all the way through paint was documented on here and perhaps a search might bring it up.
Best,
ps.....found it: http://www.vansairforce.com/communit...highlight=sexi
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-21-2011, 11:37 AM
Bob,
I was referring to your group as well as the teen flight group. Those are the only two that I was aware of. I meant "high school group" to mean of high school age.
Maxwell,
Do you know how the funding/financing of that project is being structured and how the aforementioned decisions are made? Is there some sort of voting/bi-law structure? Do all 7 members have ownership rights?
Pierre,
Thank you for that as well. I tried searching myself but did not come up with that example. I guess my google-fu is off today.
