Old 12-20-2011, 10:23 PM
albertaflyer albertaflyer is offline
Default Which andair fuel selector?
Hi,
Merry Christmas to all and a happy new year! My question is which fuel selector do most use, left/right/off or left/both/right/off? Thanks in advance. I'm looking to replace the stock kit one.
Old 12-20-2011, 10:36 PM
jbagley's Avatar
jbagley jbagley is offline
AFAIK you can't have both tanks selected in a low wing airplane.
Is this a trick question?
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 12-20-2011, 11:01 PM
Actually, never really thought about it but did a search and found an explanation. It makes sense.
Old 12-20-2011, 11:40 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Order it from Vans and you'll get the right one
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 12-21-2011, 08:11 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default fuel Valve
Andair fuel Valve.
I got mine out of spruce.
I have Left, Aux, Right, Off
My thinking is If I ever wanted to make a long ferry flight I could install a tank and plum it into the Aux. The Aux is pluged and not used, but is avialiable if and when I want to use it. The Aux is labeled OFF for now.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 12-21-2011, 09:20 PM
That's a good idea! I will keep that in mind.
Old 12-21-2011, 09:30 PM
rhill rhill is offline
Default Andair
Would this be a replacement for your 6? They make a 7T model has the fittings pointed down so there is no wasted space or need of banjo fittings ,also has right /left/off set in a y pattern.
