I just installed the Dynon servos in a closed wing. Although I am not flying yet I had to de-install the Blue Mountain servos I had put in when they went belly up. The servos and wiring are the same for all Dynon products now, only different if you have older servos and you're trying to upgrade to Skyview. I had no problem installing the servo in my closed wing and pulling the wires through the conduit. It was really much easier, lighter, and altogether a better install than what I had in there previously. We are lucky that Dynon makes brackets for our airplane and it is a snap to install.
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 08/20
