Old 12-20-2011, 03:27 PM
eddieseve eddieseve is offline
Question Wing spar bolt holes for tricycle undercarriage
Hi guys,
I am building a tail dragger RV7, and was wondering if the holes in the centre spar where the rear wheels attach if building a tricycle undercarriage version are left without bolts or if these holes need bolts installed?
Regards,
Eddie
Old 12-20-2011, 04:02 PM
ArVeeNiner's Avatar
The bolts that hold the main gear weldments to the center spar on a trike are also the bolts that hold on the wings. Are those the bolts you're talking about?
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 12-20-2011, 04:52 PM
Hi Kelly,
Perhaps I am wrong about the gear attaching here, as the holes I am talking about are actually between the rivets in the top part of the spar so there is no way that the wing would slide past these?
Eddie
Old 12-20-2011, 05:07 PM
This is not my spar, but I hope illustrates what I mean, just above the Green sticker there is a bolt hole, to the right of this is a solid rivet.
[IMG][/IMG]
Old 12-20-2011, 05:10 PM
Walt's Avatar
Walt Walt is offline
Yes, all holes get filled.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-20-2011, 05:41 PM
Paul LeDoux's Avatar
Paul LeDoux Paul LeDoux is offline
If I remember correctly the bolts that go in the unused holes are in a bag marked 999. That was for an RV-8 kit.
But my mind is old!
Paul
Old 12-20-2011, 06:44 PM
Thanks guys, much appreciated
Eddie
