Old 12-20-2011, 12:11 PM
Wesael's Avatar
Wesael Wesael is offline
Default What good is the Alt Breaker
Ok so think about this with me.....
The wire from the Alt to the breaker (commonly installed some place in the instrument panel) is not protected.
If I eliminate the breaker in my application (wire from the alt to the starter relay there will be less unprotected wire and as a benefit there will be NO unprotected wire inside the cockpit.
Has anyone used a fusible link at the alt?
Any other ideas?
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
I have changed my User Name to the correct spelling as it became availible. Please direct all correspondence to Weasel
Old 12-20-2011, 12:16 PM
rocketbob's Avatar
Not sure what you mean. The breaker IS protecting the wire its connected to.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-20-2011, 12:24 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Hmmm, not if the wire shorts to ground between the alternator (source) and the breaker...
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 12-20-2011, 12:27 PM
Sid Lambert Sid Lambert is offline
I assume you mean the B lead from the alt?
If so, I am a big fan of not having that heavy wire inside the cockpit. I run from the ALT to a current limiter next to the master or starter relay. Then run a solid copper bar between the current limiter and master/starter relay. http://www.bandc.biz/anlcurrentlimiterbase.aspx
There is no way in **** I'm going to reset a 60 AMP breaker in flight so why even have it? You still have the means to kill the ALT with a breaker to the field as well as a switch in most setups.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 12-20-2011, 12:47 PM
rocketbob's Avatar
Its the battery and electrical system that have to be protected, not necessarily the alternator.
N8155F C150 flying
Old 12-20-2011, 01:19 PM
Toobuilder's Avatar
...Has anyone used a fusible link at the alt...?
Yes, I added a fusible link at both the main and standby alternators, just like a car.
In my "emergency kit", I have a spare link for each alternator, pre terminated with a ring terminal and a crimp splice. Field replacement should only take a minute once the cowl is off.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-20-2011, 01:35 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Ditto--ANL current limiter on the front side of the firewall. Look at the Aeroelectric Connection book if you haven't already.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 12-20-2011, 02:07 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Field Breaker
Is it possible that the CB in question is the Alternator Field breaker? In my plane, this is a 5A breaker on the panel.
I too used the Aeroelectric Connection schematics as the starting point for my electrical system and this is what Bob N. recommended. I presume it's to protect against short in the field itself or if the field wire is shorted to ground ....that and the fact that all circuits off the main power bus should have protective device installed close to the bus.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 12-20-2011, 02:24 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by RV10Rob View Post
Ditto--ANL current limiter on the front side of the firewall...
Same here.
(Click to enlarge)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-20-2011, 07:17 PM
Wesael's Avatar
No. The wire in question is the main B terminal on the alt.
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
