Old 05-27-2006, 11:51 AM
idleup idleup is offline
Default When is the best time to paint the interior?
I was making the center flap motor mount and it was saying to safety tie the flap motor actuator to the flap arm. There is no way I am going to final install that this early in the process before I paint the interior, I dont even think I have most of the interior built. Anyway, this leads to me wonder after which step of construction are most people painting the interior? I cannot tell which step will not require additional brackets or parts to be fabricated for the interior.
Also, when you paint the -A model interior do you paint the landing gear weldments even though they are powder coated? If so, how do you prep them for paint?
Matt
Old 05-27-2006, 12:22 PM
N916K's Avatar
N916K N916K is offline
Matt
Once you get the floors in you are about ready to paint. Anything that attaches with screws can be painted later. About the gear mounts. I installed those after I painted and just masked the area off and shot them after they were installed. If you use a good paint (not a rattle can) you can usually touch up areas quite easily. The interior isn't that sensitive to a good paint job. There isn't large smooth surfaces that you can see from a distance.
Cam
Santa Ana, CA
RV-9 at KFUL
Old 05-27-2006, 02:20 PM
I've been painting as I go, but I'm just useing a Rustoleum hammered finish rattle can. But I did the flap housing when I was where you are now, baggage floors, center cover....side covers in the bagage compartment , canopy frame etc., as I went.
At some point -- probably now -- (wings about to get mated, finishing kit due next week), I'll mask off the rest to shoot the bulkheads etc. I'll hae upholsery here and there so I'm not going to waste time or weight in a lot of areas.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-27-2006, 02:53 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Why?
I can see the panel needing a little paint to help with glare issues but I would leave the rest alone... just more cost, weight, build time... and what do you gain? Nada.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 05-27-2006, 02:56 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I left everything unpainted below the upper longerons except the heater cover. I painted the instrument panel, roll bar, and the aft upper skin with rustoleum rattle can stone paint. I used corrugated panels covered with fabric below the arm rests, then fabric covered foam between the longerons and bulkheads. Carpet covers the floor. Very simple, good looking, and no wear points to touch up later.
Roberta
Old 05-27-2006, 04:41 PM
mgomez's Avatar
mgomez mgomez is offline
Roberta
Roberta,
Corrugated panels? What are those?
Martin
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 05-27-2006, 06:53 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Wait as long as possible
From my experience, wait as long as possible. As an example, near the end of the construction, after you have had EVERYTHING installed, and before you put the wings on for the final time would be a good time. Take the removeable stuff out and paint before putting everything back together before inspection. By waiting you will done with most of the wrench dropping, cutting and fitting of things etc....
I also wholeheartedly agree with Roberta to only paint what you need to paint. If you are doing an interior find some photos or look at a couple of planes with this type and see what is exposed. I am installing the interior from Abby at Flightline and now realize how much of the interior I did not need to paint.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-27-2006, 07:29 PM
RV7ator RV7ator is offline
I paint after everything is fitted to the fuse (excepting flying surfaces), but clunky blockages like roll bars, slider rails, upper forward fuse structure, etc., can be detached or aren't yet riveted. Then turn the fuse upside down. Real easy (relatively speaking) to stick your head in front to rear to see what you're doing, get a straight shot into difficult corners, and the hose won't drag dirt in to fall on the floor. If the fuse is right side up, you often are shooting back at yourself to paint under overhanging stuff, like F705, and you can't judge application. Also, I use an airbrush in tight areas, and a touch-up gun for everything else.
John Siebold
Old 05-27-2006, 07:43 PM
szicree szicree is offline
I have used AKZO primer on everything on my plane except for all those surfaces that will show in the cockpit. Those I primed with light gray PPG DP epoxy primer and that's it. Tough as nails and looks a lot better than that AKZO green. All this was done before assembly.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 05-28-2006, 05:28 AM
I got the panels from Airtec interiors. The stuff is like corrugated cardboard, but white, and plastic-like. It's made for interior panels.
Roberta
Here is a shot of an uncovered panel being fitted.
Here is a shot of the finished panel installed.
