Old 12-19-2011, 06:11 PM
JSBergen JSBergen is offline
Default magnetic interference with Garmin GMU-44
I am fitting up the Garmin GMU-44 in an RV-9A at the recommended location in the right lightening hole on the rear deck located just below the vertical stabilizer. I am also planning on having a manual trim system. The cable for the trim runs about 8 inches from the GMU-44. Garmin recommends 3 feet distance from metal cables. Has anyone used the GMU-44 with the trim cable located near it? If so, was there any noted interference? If there is interference, has anyone "Degaussed"sp? a cable? I am not familiar with degaussing, where/how does one do this (if necessary)?
Any thoughts would be appreciated.
Regards,
Jamie
Old 12-19-2011, 11:23 PM
Hey Jamie, this is what I used on my cables.
Prior to using this on my seatbelt restraint cables I got handheld compass swing but after degausing the cable, no magnetic swing.
So this should do the trick....I hope.
http://www.amazon.com/gp/product/B00...VYGATXMC9KC7K5
Regards
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 12-20-2011, 09:13 AM
Ironflight's Avatar
VAF Moderator / Line Boy
If you are far enough along with the system's wiring that you can power up the G3X, there is a built-in magnetic interference check in the software that you can use very easily to see if you even have a problem or not. You'll have to run that before you can calibrate the magnetometer anyway, but you can use it when you get the system powered.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
