Old 12-19-2011, 01:28 PM
rocketbob's Avatar
Default throttle travel equation
Question for a math whiz. I'm fairly good at math but I can't remember how to determine the following geometry problem.
I built a custom throttle quadrant and want to determine mathematically where the location up the throttle lever arm that would give me 2" of cable travel. Lets say the stops are on a 4" radius from the throttle arm pivot. How do I determine the distance from the pivot hole to get exactly 2" of cable travel? Width of the arm is 1/2". The stops are 1/4" in diameter.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-19-2011, 01:39 PM
Greg Arehart's Avatar
Bob,
Circumference of a circle is 2 (pi) (radius), so the travel in a complete circle would be slightly over 25 inches.
25 inches divided by 360 degrees = .007 inches/degree
2 inches times 0.007 inches/degree = 29 degrees of travel.
You can do this backwards if you know how many degrees of travel you have, and that would give you the distance out from the center for your pivot point. The width of the arm is irrelevant.
Since your motion is around a circle (not straight-line, which is what you really want to calculate), I would add another few degrees of travel so that you run against the stops at the far end of the cable, not on the quadrant itself.
[edit] just reread the original and I'm not sure I answered the exact question, but to do so requires me to know the degrees of travel (or at least distance along the arc) between your stops.
cheers,
greg
Greg Arehart
N 7965A
Old 12-19-2011, 01:57 PM
rocketbob's Avatar
Actually Greg I don't believe you are correct since you're saying that the travel is the same at .007" per degree at a 4" radius and a 2" radius...it would be smaller at a 2" radius. If I'm understanding correctly.
N8155F C150 flying
Old 12-19-2011, 02:09 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default AutoCad
Rocket Bob,
I'm at a CAD station and tried to lay out your problem but I need to know the distance between stops on the 4" radius.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 12-19-2011, 02:18 PM
szicree szicree is offline
Default This'll work
Put a mark at an arbitrary location on the center line of the arm. Let R be the distance from this mark to the lever pivot. Swing the lever from stop to stop and measure the straight line distance travelled by the mark. Call this distance D. If we let r be the distance that you're trying to find, it will be given by r=2R/D.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 12-19-2011, 02:19 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
It's a linear relationship.
Assuming the same angle between the cable and the lever arms (lets say they are perpendicular at mid travel) 30 degrees of throttle lever travel at a 4" radius will provide 1/2 as much travel at a 2" radius.
Without knowing how big of an arc you have, I can't answer specifically.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 12-19-2011, 02:45 PM
rocketbob's Avatar
I'll post a pic of the quadrant tonight since I modeled it in Solidworks, and can get the angle of travel between the stops. The real thing is made exactly how I modeled it. So if travel is constrained to be x degrees, what is the formula to get the diameter of a circle with 2" of distance between two secant points x degrees apart.
N8155F C150 flying
Old 12-19-2011, 03:01 PM
The distance between the two secant points should be 2*r*sin(angle/2). Or more specifically, the radius, r from the pivot should be:
(Cable throw distance) / (2*sin(angle/2))
Guy Prevost
Albuquerque, NM
stevemcgirr stevemcgirr is offline
Default maybe
Since you have not set the degrees of travel for this problem, set the degrees as variable "a", and you could visualize this as two right triangles mirrored, and set the desired radius as "r". The "side opposite" the angle (sine) is 1" for each right triangle, giving a ratio of:
1/r=sin a
So if you know the angle, you derive the radius, or vice versa
At least I think so...
BTW in this ratio the angle "a" gives 1/2 the total. Angle a is for each of the two halves, so total angle would be 2a
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
Old 12-19-2011, 03:03 PM
Flying Scotsman Flying Scotsman is offline
Do you want the 2" between points to be arc length, or just point-to-point as measured in the "usual" sense (Euclidean distance)?
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
